Download link for makemkv-oss-1.15.4.tar.gz is broken
calinb
#1 Post by calinb » Mon Dec 14, 2020 10:23 pm
The link is broken here:
https://www.makemkv.com/forum/viewtopic.php?f=3&t=224
The correct link should be (delete the "old" in the URL path):
https://www.makemkv.com/download/makemk ... 5.4.tar.gz
calinb
Re: Download link for makemkv-oss-1.15.4.tar.gz is broken
#2 Post by calinb » Mon Dec 14, 2020 10:34 pm
Nope. Despite the filename, the archive link I guessed and provided doesn't produce a correct 1.15.4 oss file structure. It's a misnamed archive of 1.15.3 oss apparently.
Mike will have to fix it.
#3 Post by dcoke22 » Mon Dec 14, 2020 10:38 pm
viewtopic.php?f=3&t=23933
The 1.15.3 version should work fine.
calinb
#4 Post by calinb » Mon Dec 14, 2020 10:41 pm
dcoke22 wrote: Mon Dec 14, 2020 10:38 pm viewtopic.php?f=3&t=23933
Thanks, dcoke22! I'll try it. Guess my 1.15.4 search string wasn't very effective in leading me to the solution.
hornetster
#5 Post by hornetster » Tue Dec 15, 2020 12:29 am
First visit, about to try the software on Linux, and, yes, the link is still broken...
OK to download the older one, but still use the newer ***-bin-1.15.4*** file?
Oh, and where ARE the older versions...?
hook77
#6 Post by hook77 » Wed Dec 16, 2020 11:00 am
the link is still broken, however, no problem to remove "old" from the URL.
I was able to build and install the 1.15.4 w/o any problems.
Funny: The "Info" Dialog says "MakeMKV" and "GUI Version" is 1.15.4, while the "latest version" is 1.15.3.
There was no notification for an update, by the way ...
Regards, hook
#7 Post by d00zah » Tue Sep 26, 2023 10:35 am
eliana78 wrote: Tue Sep 26, 2023 5:11 am ... I'm also having trouble finding the repository for previous versions.
https://www.makemkv.com/download/old/
