Dolby Vision and 1.15.3
phneutral
Re: Dolby Vision and 1.15.3
Post by phneutral » Fri Dec 11, 2020 4:57 pm
1.15.4 is out now folks, there's no need to jump through hoops anymore :D I'm just running my dual layer MKV's through it and a single layer DV MKV comes out nicely the other end :mrgreen:
thanks for this amazing program!!!
azreil24
Post by azreil24 » Mon Dec 14, 2020 3:32 pm
Hi guys. Sorry if I missed this, but didn't get through all the pages yet. I found that dvhe.08.06 works on my LG C8 with DV and DA, but when I make my own remuxes, how do I chose or change this version? Or do you change this in the tsMuxer? Thanks and sorry for the noon questions :oops:
chiavere
Post by chiavere » Mon Dec 14, 2020 8:34 pm
Hi All,
Not sure if I missed something, but I'm on 1.15.4 with a Dolby Vision disc (10 Cloverfield Lane), and I can't figure out how to extract a DV MKV - I don't see it showing up anywhere -- this is what I see when I go to extract (see attached) the disc. Do I extract both of these ~50gb files to get DV, or ? I don't know how folks are making "dual layer" MKV, and don't see that as an option in MakeMKV.
Can someone do a quick step by step? I see that Plex has just updated the iOS app with DV support, so hope springs eternal!
Thanks.
Screen Shot 2020-12-14 at 2.22.13 PM.png (25.94 KiB) Viewed 36921 times
Post by dcoke22 » Mon Dec 14, 2020 11:01 pm
chiavere wrote: Mon Dec 14, 2020 8:34 pm Not sure if I missed something, but I'm on 1.15.4 with a Dolby Vision disc (10 Cloverfield Lane), and I can't figure out how to extract a DV MKV - I don't see it showing up anywhere -- …
Click the triangle to open it up. On the Video line you should see something like this:
That lets you know MakeMKV sees the Dolby Vision info and will output it in the resulting MKV file.
chiavere
Post by chiavere » Tue Dec 15, 2020 2:08 am
Ah, ok, many thanks - that is there, so I guess Plex is the issue - it’s not seeing the DV, just HDR, even after today’s update. Bummer!
oldirtydog
Post by oldirtydog » Tue Dec 15, 2020 5:55 am
Hi guys,i tested makemkv 1.15.4 with 5 FEL movies but on the five i see HDR not vision.
Mr_Orange
Post by Mr_Orange » Tue Dec 15, 2020 8:06 am
oldirtydog wrote: Tue Dec 15, 2020 5:55 am Hi guys,i tested makemkv 1.15.4 with 5 FEL movies but on the five i see HDR not vision.
You need to be more specific!
What is your playback chain?
oldirtydog
Post by oldirtydog » Tue Dec 15, 2020 8:32 am
Mr_Orange wrote: Tue Dec 15, 2020 8:06 am
Zidoo Z9X
phneutral
Post by phneutral » Tue Dec 15, 2020 4:39 pm
chiavere wrote: Tue Dec 15, 2020 2:08 am Ah, ok, many thanks - that is there, so I guess Plex is the issue - it’s not seeing the DV, just HDR, even after today’s update. Bummer!
No issues here with Plex! Have you tried restarting the movie a few times? Are you on latest Plex beta? (not sure if DV playback is still in beta)
Easiest way I've found to avoid playback issues is to delete, rescan, empty trash and re-import the movie to the library.
AndreasT
Post by AndreasT » Wed Dec 16, 2020 11:48 am
Kolci wrote: Sat Oct 24, 2020 8:06 am Is there a way to convert dvhe.07.06 to dvhe.04.06 or dvhe.05.06 profiles?
Did you ever get an answer to this, either here or somewhere else? Anyone knows if possible and how-to?
chiavere
Post by chiavere » Wed Dec 16, 2020 5:52 pm
phneutral wrote: Tue Dec 15, 2020 4:39 pm
Ok, will try that, but for the Movie listing it doesn't say "Dolby Vision" just "4K (HEVC Main 10 HDR)", so I don't know if it's picking up the DV. I am not on the Plex beta, just the current 1.25.0.1511-47afccd4 release (which I just updated to now, so I will test again).
Attached is the media info file detail - assuming the "D O L V I" listings are Dolby Vision, I guess maybe it is recognizing the DV metadata in the file?
Thanks, all!
Screen Shot 2020-12-16 at 11.47.32 AM.png (57.4 KiB) Viewed 36677 times
Post by shawnc22 » Wed Dec 16, 2020 10:01 pm
chiavere wrote: Wed Dec 16, 2020 5:52 pm
Thanks, all!
There is no indicator for DV on Plex clients for now. If your device can play them, you simply just have to test it by playing them.
Mr_Orange
Post by Mr_Orange » Wed Dec 16, 2020 10:35 pm
The DOVI entries are the Dolby Vision metadata.
chiavere
Post by chiavere » Thu Dec 17, 2020 2:29 am
shawnc22 wrote: Wed Dec 16, 2020 10:01 pm There is no indicator for DV on Plex clients for now. If your device can play them, you simply just have to test it by playing them.
Ok, thanks - I am on a Dolby Vision capable LG CX TV, so I guess MKV w/ DV for Plex on that isn’t working yet.
I tried both casting from the iOS Plex app and also using the LG native Plex app, but only got HDR playback from the DV MKV.
Mr_Orange
Post by Mr_Orange » Thu Dec 17, 2020 3:16 am
You need a Shield to get DV playback from an MKV.
