Midway question
charlie62
Midway question
Post by charlie62 »
I have the UK version and it has the protection that makes makemkv choose the wrong file. Looking thru the US version it also has a file no.504 and the mts numbers are the same,the only difference is the last numbers on mine are t.90 whereas the US version is t.98. Does the last numbers being different mean it is a different file and a wrong one. Thanks
Re: Midway question
Post by SamuriHL »
It's not really possible for us to know. What does MakeMKV show as the sequence when you look at title 504? We could compare it to the US version and see if it's the same but even that's no guarantee.
charlie62
Re: Midway question
Post by charlie62 »
The UK sequence for 504 is the same as the US disc up to the last one one being 90 the other being 98. Thanks
kingston12
Re: Midway question
Post by kingston12 »
I'm having the same issue. I think it is most likely to be 504, because the segment map is the same, it's just the filename that is different. Here is the detail on the US disc from the other thread:
Title information
Name: Midway (English)
Source file name: 00504.mpls
Duration: 2:18:25
Chapters count: 16
Segment count: 1
Segment map: (502,501,503,500,506,507,505)
File name: Midway_t98.mkv
...and here is what I'm getting from the UK disc:
Title information
Duration: 2:18:25
Chapters count: 16
Segment count: 1
File name: Midway_t90.mkv
Re: Midway question
Post by SamuriHL »
Yea I think you guys are good:
00502.M2TS 0:00:00.000 0:37:17.068 22,137,507,840 79,166 kbps
00501.M2TS 0:37:17.068 0:00:47.297 492,189,696 83,250 kbps
00503.M2TS 0:38:04.365 0:01:22.582 839,534,592 81,328 kbps
00500.M2TS 0:39:26.947 0:00:44.461 448,788,480 80,751 kbps
00506.M2TS 0:40:11.409 0:16:57.891 9,999,937,536 78,593 kbps
00507.M2TS 0:57:09.300 1:05:35.181 38,911,076,352 79,104 kbps
00505.M2TS 2:02:44.482 0:15:40.773 7,254,208,512 61,687 kbps
That's from the US disc.
kingston12
Re: Midway question
SamuriHL wrote:
Wed Mar 11, 2020 3:52 pm
Thanks. How do you get that information from the disc?
Re: Midway question
Post by SamuriHL »
Another product provides BDInfo output to text files. It was the first to support these UHD screen pass discs.
charlie62
Re: Midway question
Post by charlie62 »
I'm now getting a different file no.373 on the UK version of Midway. The one I used before was file no.504 which seemed to be ok although I haven't watched it all. Thanks
boomer
Re: Midway question
Post by boomer »
I bought the Best Buy version of Midway and am unable to find the correct file for the Blu-Ray disk. There are 200 copies of it. Can anyone tell me how to find which one is the correct one?
FurQ666
Re: Midway question
Post by FurQ666 »
I haven't attempted to rip my disc yet. Is 504 now confirmed as the correct title for the UK version?
Simbo
Re: Midway question
Post by Simbo »
Has this been confirmed yet?
I ripped the 504 playlist from my UK copy before work and had a quick flick through the .mkv once it had finished but in my opinion it looked like the scenes weren’t in the correct order.
The segments matched those from the US 504 playlist but it didn’t look right to me.
Stryker412
Re: Midway question
Post by Stryker412 »
So 504 on the US disc is the correct one?
Re: Midway question
Post by SamuriHL »
Yes.
Impac
Re: Midway question
Post by Impac »
I need the correct title for Midway 2019 Blu-ray disc pleqase help. 504 is not on the disc or 768 mpls
Re: Midway question
Title information
Comment: FPL_MainFeature
Source file name: 00539.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 504,510,501,507,502,505,506,509,503,508
File name: Midway-FPL_MainFeature_t09.mkv
That's what it is for me… that's the blu-ray disc bundled with the US UHD release.
