Dances with Wolves - No Subtitles
servocrow
Dances with Wolves - subtitle problem
#1 Post by servocrow » Wed Jan 12, 2011 12:27 pm
I would have thought that this BR would have had these subtitles HARDCODED for the SIOUX speaking parts of the film, but it is not. I have tried several times to rip this via MAKEMKV and to incorporate any and all english subtitles. It will not work...help please.
Psion69
#2 Post by Psion69 » Wed Feb 16, 2011 4:59 pm
Hi Everyone,
I've been having a hell of a time getting Dances with Wolves to show subtitles. I've ripped with AnyDVD HD played the stream for the main movie and no subs appeared no matter what player I use. Tried Ripbot and that didn't work. ClownBD produced similar results. Today, I tried Makemkv and had "both" English subs (forced only) checked, though I don't know why there are two to begin with. I unticked the Spanish and French and did the conversion. Again, no subs appear for all the scenes the Sioux speak.
What's going on? Has anyone encountered this problem, even on other discs?
Thanks.
Psion69
Re: Dances with Wolves - subtitle problem
#3 Post by Psion69 » Wed Feb 16, 2011 5:01 pm
Hey, I didn't see your post. I, too, have had the same problem as you. Ripbot, ClownBD, AnyDVD, DVDFab 8, you name it and nothing works. Have you found a solution yet?
Marc_G
#4 Post by Marc_G » Thu Feb 17, 2011 1:18 am
Does your player routinely show PGS subtitles from BD streams? If not did you convert them per instructions elsewhere?
I've found an alternative solution for where that doesn't work: using AnyDVDHD as the decrypter, using AnotherEAC3ToGui to do the rip will usually autoconvert PGS subs to the dvd style subs that MPC-HC can play.
Sorry to post a solution using alternative products, but since most players of MKVs don't handle PGS subs well, the lack of a subtitle conversion option built into MakeMKV is a serious drawback for me. I would have bought a license already if not for this issue.
Otherwise I'm a faithful MakeMKV devotee.
8)
Psion69
Re: Dances with Wolves - No Subtitles
#5 Post by Psion69 » Sat Feb 19, 2011 1:31 am
Thanks. I'll try out your suggestion. This is really annoying me. :D
VideoWolf
#6 Post by VideoWolf » Sat Nov 19, 2011 6:01 pm
I have this same problem with District 9. cant get the "Alien Speak" forced subtitles to appear no matter what I try. seems if I want forced only subtitles, I have to rip it from the DVD copy. & that sorta kills the reason for having it on BR.
Would be nice if MakeMKV could rip all subtitles on a movie into a separate SRT file, including Forced Only Subs.
crowfax
#7 Post by crowfax » Sat Nov 19, 2011 6:57 pm
MakeMKV pulls the forced subtitles to their own stream inside the MKV file. You just need to use playback software that can handle PGS subtitles.
setarip_old
#8 Post by setarip_old » Sun Nov 20, 2011 1:25 am
@crowfax
Hi!
Such as? (Please list)
crowfax
#9 Post by crowfax » Sun Nov 20, 2011 4:56 am
Do I look like your servant? If you'd like to request someone do something for you, manners wouldn't go amiss.
Still, lets ignore the rudeness and I'll help you anyway.
For Windows I use this:
Media Player Classic - Home Cinema
On Linux I use this:
SMPlayer
They both support PGS subtitles.
setarip_old
#10 Post by setarip_old » Sun Nov 20, 2011 5:40 am
@crowfax
1) I guess saying "Please list" somehow isn't polite enough?
2) I don't need your help on this topic, but the reason I asked you to "please list" some of the players that will do what you say, is that only stating as you did that:
doesn't really help the OP...
Glad to see that your last post does list a couple of such players ;>}
crowfax
#11 Post by crowfax » Sun Nov 20, 2011 5:54 am
setarip_old wrote:I guess saying "Please list" somehow isn't polite enough?
100% correct. However I'm uninterested in teaching you manners; so don't ask for pointers, that's a good chap.
setarip_old wrote:I don't need your help on this topic
Oh, so you could have helped the OP but didn't. Charming behavior.
This has gone off topic, if the OP needs more help, they can ask themselves.
