BU40N - Which firmware is best?
bachelorbob
Re: BU40N - Which firmware is best?
#31 Post by bachelorbob » Sun Dec 13, 2020 3:21 pm
MartyMcNuts wrote: Thu Dec 10, 2020 5:50 am
bachelorbob wrote: Thu Dec 10, 2020 5:44 am Is there any way to extract / dump the stock BW42 firmware from my hp HLDS BU40N drive on a Mac (connected via an external USB3 enclosure) before I flash downgrade it? Is there a real need for the stock firmware?
Contact Mike Admin. He may want a copy of that firmware. If he can extract it remotely, he should also send you a copy.
Sent extracted FW dump to Mike Admin. PM still unread. No reply.
Would flash with another FW if I could *find* one. Lots of "download this or that," but never a link or location.
#32 Post by d00zah » Sun Dec 13, 2020 3:32 pm
Ultimate UHD Drives Guide Updated 2020
1st post provides links to FW/tools, instructional vids, etc..
Fcastril
#33 Post by Fcastril » Sun Dec 13, 2020 7:31 pm
Hi!
I bought an HL-DT BU40N which came with firmware 1.04.
I have successfully downgraded it to 1.03mk.
It's ok for MakeMKV but does not work with DvdFab.
I need version 1.00 or maybe 1.01 for DvdFab.
Can someone post them because I searched but couldn't find them?
Thank you
#34 Post by Billycar11 » Sun Dec 13, 2020 9:12 pm
bachelorbob wrote: Sun Dec 13, 2020 3:21 pm
It's unlikely you will get anyone to backup your firmware for you as it takes an hour and no one has anything to gain from this.
It's not new firmware where we have to figure out a new workaround and will add to help the community. The whole point of these new flashers is they are safer to flash as it's the same way the oem updaters work.
If you didn't want to flash your own drive because your scared you should have bought one from one of the sellers
rdgrimes
#35 Post by rdgrimes » Wed Jan 06, 2021 3:37 am
Fcastril wrote: Sun Dec 13, 2020 7:31 pm Hi!
Thank you
Me too
#36 Post by Billycar11 » Wed Jan 06, 2021 3:39 am
rdgrimes wrote: Wed Jan 06, 2021 3:37 am
Thank you
Me too
if only we all read my guide where its all linked its almost like i made it for no reason
https://www.makemkv.com/forum/viewtopic ... 873#p70284
bachelorbob
#37 Post by bachelorbob » Sun Jan 10, 2021 3:01 am
Billycar11 wrote: Wed Jan 06, 2021 3:39 am if only we all read my guide where its all linked its almost like i made it for no reason
While the guide is much appreciated, finding it and locating the resources are nowhere near as straightforward as they could be. If the forum's board index had a 'download' section, with Windows and Mac sub-sections…
I would also make the 'MK firmware pack' far less cryptic. Folders of BU40N-FR, BU40N-N-Main, BU40N-R-Tier2-Taiwan, BU40N-U-Tier2-Non-UHD (for just the BU40N drive) leave all but the diehards confused. Imagine if the MakeMKV application actually auto-generated a link to download the best firmware for each drive it recognized!
Ultimately, all *I* needed was the sdf.bin, DE_LG_BU40N_1.00.bin firmware, and the correct command line syntax; ALL of which were unnecessarily difficult to locate. Could have taken a few minutes, rather than multiple days of reading.
Szeizer357
#38 Post by Szeizer357 » Sat Jan 29, 2022 11:57 pm
Speed aside, is it necessary to upgrade v1.00 to v1.03 or v1.03MK to avoid the sleep bug? Or is only a given factory version without it, and flashing will introduce it? Or is there a range of 'good' versions?
#39 Post by Billycar11 » Sun Jan 30, 2022 1:10 am
Szeizer357 wrote: Sat Jan 29, 2022 11:57 pm Speed aside, is it necessary to upgrade v1.00 to v1.03 or v1.03MK to avoid the sleep bug? Or is only a given factory version without it, and flashing will introduce it? Or is there a range of 'good' versions?
Bu40n has no sleep bug at all
usernames-all-gone
#40 Post by usernames-all-gone » Tue Mar 31, 2026 6:10 pm
bachelorbob wrote: Sun Jan 10, 2021 3:01 am
I've been an IT professional for decades and it took me the equivalent of one full business day to collate the information required to safely flash a drive, not to mention a copy of MakeMKV 1.17.7 from the Wayback Machine because it was deleted from the website but nothing newer works on Linux (or perhaps on macOS either).
A forum is not the right place to collate this information; a wiki is.
That said, I will be purchasing MakeMKV to support the project.
#41 Post by MartyMcNuts » Wed Apr 01, 2026 6:14 am
usernames-all-gone wrote: Tue Mar 31, 2026 6:10 pm
What's was wrong with grabbing an old version? https://makemkv.com/download/old/
usernames-all-gone
#42 Post by usernames-all-gone » Wed Apr 22, 2026 10:03 am
MartyMcNuts wrote: Wed Apr 01, 2026 6:14 am
usernames-all-gone wrote: Tue Mar 31, 2026 6:10 pm I've been an IT professional for decades and it took me the equivalent of one full business day to collate the information required to safely flash a drive, not to mention a copy of MakeMKV 1.17.7 from the Wayback Machine because it was deleted from the website but nothing newer works on Linux (or perhaps on macOS either).
Does that link exist anywhere on the Downloads page? I sure can't spot it there...
#43 Post by Woodstock » Wed Apr 22, 2026 2:43 pm
usernames-all-gone wrote: Wed Apr 22, 2026 10:03 amDoes that link exist anywhere on the Downloads page? I sure can't spot it there...
It doesn't appear on the download page, but it is where the old (and current) versions are kept.
usernames-all-gone
#44 Post by usernames-all-gone » Thu Apr 23, 2026 10:38 am
Woodstock wrote: Wed Apr 22, 2026 2:43 pm
How do you expect people to find it then?! As many have said, a wiki is the better place to keep (and maintain) a single source of truth.
#45 Post by Woodstock » Thu Apr 23, 2026 2:53 pm
That is a question to ask Mike Admin, who maintains the links.
Generally speaking, though, he could feel that most people wouldn't need old versions, so they're available but not prominently so. For those who don't have permanent keys, extracting an old version would present you with the "old key" issue, if you didn't also pull the current version to install the current key.
Personally, I keep half a dozen versions installed, so I can test things with different versions, but I've had a permanent key for over 15 years, so that isn't an issue.
