MakeMKV v1.6.3 darwin(x86-release) started
Opening files on harddrive at /Volumes/SansDigital/Movies/Artificial Inteligence/VIDEO_TS/
Titleset id 0 is invalid
setarip_old
Re: Artificial Inteligence
Hi!
Does the DVD play properly on your computer?
Does the DVD play properly on a standalone DVD player?
Check for physical damage and or dirt. Try cleaning the disc.
It's a rip I did a while back. Plays fine.
Debug logging enabled, log will be saved as /Users/viewer/MakeMKV_log.txt
Opening files on harddrive at /Volumes/Movies/Artificial Inteligence/VIDEO_TS/
DEBUG: Code 0 at C&L\-k/}qO".d\.sa:29394045
setarip_old
Try re-ripping your original, commercial DVD DIRECTLY (and ONLY) with MakeMKV...
Got it to work by converting to ISO using:
http://sourceforge.net/projects/aquaiso/
Then using MakeMKV.
Note choose the parent folder of the Video_TS folder while using AquaISO and not the acvtual Video_TS folder.
Then using MakeMKV.
setarip_old
Did you retry (without creating an .ISO image file) with MakeMKV pointed to your hard drive folder as: Opening files on harddrive at /Volumes/Movies/Artificial Inteligence/ (WITHOUT "VIDEO_TS")?
Tried it. Didn't work.
- Contact:
