What firmware for burning?
Wolf359
#1 Post by Wolf359 » Fri Dec 11, 2020 3:34 am
I have a WH16NS60 and was wondering if there is a firmware that will work with Cyberlink Media Suite to burn blu rays? Or is there a better program I should be using?
Re: What firmware for burning?
#2 Post by MartyMcNuts » Fri Dec 11, 2020 7:06 am
Wolf359 wrote: Fri Dec 11, 2020 3:34 am I have a WH16NS60 and was wondering if there is a firmware that will work with Cyberlink Media Suite to burn blu rays? Or is there a better program I should be using?
Please don't use Cyberlink software. Absolute garbage.. Basically anything else would be better.
Is there a reason why you want to write to blu-ray discs? Hard drive storage is much cheaper these days and you could fit a bucket load of MKV files on a drive.
Wolf359
#3 Post by Wolf359 » Fri Dec 11, 2020 2:19 pm
Okay I agree, but humor me. Does anyone recommend any burning software? Surely someone does.
#4 Post by Woodstock » Fri Dec 11, 2020 2:41 pm
I'm going to toss out the opinion that burning is not something UHD-friendly drives do particularly well, regardless of firmware or software.
Pioneer drives are well regarded for burning, but they're not UHD-friendly at this point.
Wolf359
#5 Post by Wolf359 » Fri Dec 11, 2020 3:43 pm
Okay. Thanks for the info. I sucessfully burned a disc using Imgburn and it plays on my XBONEX. Couldn't get it to play on a sony uhd player. Gonna try my other player now.
#6 Post by Coopervid » Fri Dec 11, 2020 7:25 pm
The LG based players / recorders are OK for burning BD-25. If it comes to burn BD-50 they mostly screw up at the layer break. If you want to burn BD-50 you should do this with a Pioneer burner and Japanese Verbatim BD-50 discs. Reduce burn speed to 4x or even 2x. Otherwise disturbances at the layer break also occur for discs burnt with Pioneer drives.
The BD-50 spec sucks. For DVD-DL you could specify the layer break not being at the critical outer edge of the discs. So you could avoid this area. BD-50 will just burn to the end of layer 0 and then switch to layer 1. A catastrophe because most discs and burners have issues at the outer edge of the layer.
#7 Post by Coopervid » Fri Dec 11, 2020 7:43 pm
And Imgburn freeware is the best software for burning.
Wolf359
#8 Post by Wolf359 » Fri Dec 11, 2020 8:10 pm
I do have a pioneer burner and am using verbatim discs. Are they all made in Japan or should I get certain ones?
#9 Post by Coopervid » Fri Dec 11, 2020 8:44 pm
Run this through Google translator German -> English.
https://forum.redfox.bz/threads/uhd-fil ... scs.77673/
Wolf359
#10 Post by Wolf359 » Fri Dec 11, 2020 11:32 pm
Thanks @coopervid!
Is there a pioneer drive that is good for burning bdxl discs? I see the pioneer website has at least one.
Wolf359
#11 Post by Wolf359 » Mon Dec 14, 2020 4:29 pm
Just a quick question on burning: I read that the drive I have (WH16NS60) Has problems burning dual layer discs. I have burned several with no errors but have yet to watch one all the way through (TV Show discs where I watched one episode with no problems). If it doesn't burn correctly will it just not play? Or will the break in layers be obvious on playback or will I get errors on burning or what? I have a 100 gb three layer disc burning now and will watch it carefully later (movie this time), but want to know what to expect and look for. Thanks.
