Create .iso from backup, which folders?
ttnicky
#1 Post by ttnicky » Fri Dec 11, 2020 7:24 am
Before I start, let me just say I have searched the forum before asking this question....
I created some backups using MakeMKV and am wondering how to get those into .iso files. I know I need to use other software to create the .iso. What I don't know is which folders go into the .iso. When MakeMKV creates a backup it makes three folders: BDMV, CERTIFICATE, and MAKEMKV. Do all those go into the .iso, or just the BDMV folder?
Thank you
st4evr
Re: Create .iso from backup, which folders?
#2 Post by st4evr » Sun Dec 13, 2020 2:40 am
Google is your friend. Try searching for something like this:
https://www.google.com/search?q=create% ... efox-b-1-m
Or similar.
This is a very, very common process. In very short, one of the easiest ways is with ImgBurn and you should add all the folders/files into the image.
