Roberespa
#3871 Post by Roberespa » Thu Dec 10, 2020 4:01 pm
My LG OLED55B6V TV, if it plays .ts video files with Dolby Vision.
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the command prompt "cmd" and give me a .ts video file?
Explain how I can do it.
Please!
Thank you so much everyone.
Waiting for your reply.
#3872 Post by RESET_9999 » Thu Dec 10, 2020 4:04 pm
pete19 wrote: Thu Dec 10, 2020 12:54 pm from recent memory (~ 2MB MEL layer):
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
bluray forum has a long list, there are some
Interesting, thanks! do you have a link to that bluray.com list?
The Hobbit movies are all below 100kbps though. And since Lawrence of Arabia is also a 2-disc movie, I wonder if it's related to the larger MEL.
Hobbit 1:
PLAYLIST REPORT:
Length: 3:02:29.438
Total Bitrate: 59.62 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 49451 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 69 kbps (0.14%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision MEL / BT.2020
DaMacFunkin
#3873 Post by DaMacFunkin » Thu Dec 10, 2020 4:47 pm
Roberespa wrote: Thu Dec 10, 2020 4:01 pm My LG OLED55B6V TV, if it plays .ts video files with Dolby Vision.
Please!
Create the mp4 as per the instructions with ac3 or DTS audio then run it through tsmuxer?
#3874 Post by RESET_9999 » Thu Dec 10, 2020 5:04 pm
Please!
all you need is here:
https://www.makemkv.com/forum/viewtopic ... 970#p96282
https://bintray.com/justdan96/tsMuxer/t ... htly#files
https://mrmc.tv/forum/viewtopic.php?f=1 ... &start=310
Roberespa
#3875 Post by Roberespa » Thu Dec 10, 2020 6:09 pm
RESET_9999 wrote: Thu Dec 10, 2020 5:04 pm
Please!
It is perfect to convert the movie to .mkv with MakeMKV
But when I convert it to .ts with tsMuxeR I lose the Dolby Vision layer =(
#3876 Post by shawnc22 » Thu Dec 10, 2020 7:18 pm
Roberespa wrote: Thu Dec 10, 2020 6:09 pm
Please!
What's the obsession with conversions to ts files? If you're playing it off your LG's internal player, then the mp4 method is the gold standard. TS files with merged tracks are not guaranteed to work with every movie.
#3877 Post by MartyMcNuts » Fri Dec 11, 2020 12:13 am
Please!
Which version of tsmuxer are you using??
DaMacFunkin
#3878 Post by DaMacFunkin » Fri Dec 11, 2020 6:57 am
Yousope has gone very quiet, do we think he has been head hunted, or worse ‘served notice’?
codeXRes
#3879 Post by codeXRes » Fri Dec 11, 2020 8:32 am
RESET_9999 wrote: Thu Dec 10, 2020 4:04 pm
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
This is my go to DV list for new UHD releases. Some very knowledgeable people discussing stuff too.
https://forum.blu-ray.com/showthread.php?t=276448
agneva
#3880 Post by agneva » Fri Dec 11, 2020 12:55 pm
someone has an idea, how can I extract:
-HEVC1 in 4K (Base layer)
-HEVC 2 in 1080p (DV EL)
from this mkv:
with gMKVExtract I get only one *.hevc file.
I need to create a mp4 for my LG TV:
Roberespa
#3881 Post by Roberespa » Fri Dec 11, 2020 1:14 pm
Please!
-Hi:
Finally, I have managed to make my television play Dolby Vision without being in .mp4, since it can be done in .ts or .m2ts the quality is much higher than that of the "guaranteed" .mp4.
.mp4 offers colors that tend to green and dark and the feeling of brightness and people's faces is bad.
I do not like.
Conversely;
.ts or .m2ts
offers excellent results, more realistic colors and good gloss.
I am very happy to have made it.
When I have time I will make a comment indicating the steps to follow.
So people don't have to spend hours reading forum posts. And it doesn't work for them.
I'm very happy.
Now that I have it, I would like to.
That you answer me some questions to have the "Master" in Dolby Vision =)
As far as I know, the iso file
Dolby Vision has two video layers
a .hevc
and a second .hevc
I think the first hevc that has a very large size is 4K video with HDR10,
While layer 2 hevc
It is the video that contains Dolby Vision. It is right?
* Questions from newbies:
What do BL, Mel, FEL and RPU stand for? What are the differences between Mel and Fel?
What is the best profile for a UHD with Dolby Vison 5, 7, 8 or 8.1?
Hope you can solve my rookie questions.
Thanks a million I'm very happy to have achieved it.
You are all wonderful.
I will be waiting for your answers.
Best regards.
-Rober.
#3882 Post by RESET_9999 » Fri Dec 11, 2020 4:52 pm
agneva wrote: Fri Dec 11, 2020 12:55 pm Hi,
from this mkv:
there is a demux bat here
Wanderlust3K
#3883 Post by Wanderlust3K » Fri Dec 11, 2020 9:02 pm
Yep yusepope is quite quiet.
Tested all Yusepope files (mp4) on a CX and only one would play and trigger DV, a FEL_To_81.mp4 (BL+RPU only), but it didnt look quite rigth.
is it true that BL+EL+RPU offer higher quality as opposed to just BL+RPU?
is it true that plain HDR+Dynamic Tonemaping = BL+RPU ?
Thanks and keep it up guys.
quietvoid
#3884 Post by quietvoid » Fri Dec 11, 2020 9:43 pm
Wanderlust3K wrote: Fri Dec 11, 2020 9:02 pm Yep yusepope is quite quiet.
The CX is rumored to have lost dual track mp4 support.
There's little noticeable difference with a FEL, while MEL is the same as just the RPU.
LG's dynamic tonemapping is garbage (at least on the C8).
pete19
#3885 Post by pete19 » Sat Dec 12, 2020 12:53 pm
RESET_9999 wrote: Thu Dec 10, 2020 4:04 pm Interesting, thanks! do you have a link to that bluray.com list?
I can't remember, but I think MEL only ultimately "only" creates a 10 bit 420 image, compared to FEL which results in a 12bit 422 image, as MEL does not have the difference data in the EL, just the dynamic meta data.
the 10bit to 12bit difference is negligible, the 422 is what we want.
