pete19
Post by pete19 » Thu Dec 10, 2020 3:36 am
RESET_9999 wrote:
Wed Dec 09, 2020 10:27 pm
The LOTR are MEL with an unusually high bitrate
it's not unusual, there are quiet a few MEL titles with bitrates around 2MB... and bdinfo states FEL/MEL incorrectly, can't rely on it...
just look at the bitrate itself or the play back the EL itself...
chros
Post by chros » Thu Dec 10, 2020 8:12 am
RESET_9999 wrote:
Wed Dec 09, 2020 11:22 pm
on a FEL movie, you can see the actual movie
Thank you, one last question: so what's the bloody point of using 0 padded MEL (~2 Mbps) instead of the smallest one (that I saw 64 Kbps)?
I mean there must be a reason for them... :)
Post by RESET_9999 » Thu Dec 10, 2020 12:08 pm
I have the same question... :?:
Well i went back looking at 20 of the latest DV movie i added to my library and could find one (except LOTR). Must not be that usual.
pete19
Post by pete19 » Thu Dec 10, 2020 12:54 pm
from recent memory (~ 2MB MEL layer):
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
bluray forum has a long list, there are some
Maikel777
Post by Maikel777 » Thu Dec 10, 2020 2:50 pm
Roberespa wrote:
Wed Dec 09, 2020 3:55 pm
What you say about my TV:
LG OLED55B6V
That Dolby Vision does not play without being in .mp4 "is false".
This file taken from a test website shows that my TV is capable of opening Dolby Vision, at least in .ts format
I attach the link:
https://uptobox.com/q0tk0wifzm5f
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the "cmd" command prompt and give me a .mkv or .ts video file?
Thank you so much everyone.
Waiting for your reply.
I am very interested to know how this person created this .ts
Someone could explain.
I would be eternally grateful.
Thanks a lot.
Roberespa
Post by Roberespa » Thu Dec 10, 2020 4:01 pm
My LG OLED55B6V TV, if it plays .ts video files with Dolby Vision.
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the command prompt "cmd" and give me a .ts video file?
Explain how I can do it.
Please!
Post by RESET_9999 » Thu Dec 10, 2020 4:04 pm
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
Interesting, thanks! do you have a link to that bluray.com list?
The Hobbit movies are all below 100kbps though. And since Lawrence of Arabia is also a 2-disc movie, I wonder if it's related to the larger MEL.
Hobbit 1:
PLAYLIST REPORT:
Length: 3:02:29.438
Total Bitrate: 59.62 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 49451 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 69 kbps (0.14%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision MEL / BT.2020
DaMacFunkin
Post by DaMacFunkin » Thu Dec 10, 2020 4:47 pm
Please!
Create the mp4 as per the instructions with ac3 or DTS audio then run it through tsmuxer?
Post by RESET_9999 » Thu Dec 10, 2020 5:04 pm
Please!
all you need is here:
https://www.makemkv.com/forum/viewtopic ... 970#p96282
https://bintray.com/justdan96/tsMuxer/t ... htly#files
https://mrmc.tv/forum/viewtopic.php?f=1 ... &start=310
Roberespa
Post by Roberespa » Thu Dec 10, 2020 6:09 pm
Please!
It is perfect to convert the movie to .mkv with MakeMKV
But when I convert it to .ts with tsMuxeR I lose the Dolby Vision layer =(
Post by shawnc22 » Thu Dec 10, 2020 7:18 pm
Please!
What's the obsession with conversions to ts files? If you're playing it off your LG's internal player, then the mp4 method is the gold standard. TS files with merged tracks are not guaranteed to work with every movie.
Post by MartyMcNuts » Fri Dec 11, 2020 12:13 am
Please!
Which version of tsmuxer are you using??
DaMacFunkin
Post by DaMacFunkin » Fri Dec 11, 2020 6:57 am
Yousope has gone very quiet, do we think he has been head hunted, or worse ‘served notice’?
codeXRes
Post by codeXRes » Fri Dec 11, 2020 8:32 am
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
This is my go to DV list for new UHD releases. Some very knowledgeable people discussing stuff too.
https://forum.blu-ray.com/showthread.php?t=276448
agneva
Post by agneva » Fri Dec 11, 2020 12:55 pm
someone has an idea, how can I extract:
-HEVC1 in 4K (Base layer)
-HEVC 2 in 1080p (DV EL)
from this mkv:
with gMKVExtract I get only one *.hevc file.
I need to create a mp4 for my LG TV:
