quietvoid
#3856 Post by quietvoid » Wed Dec 09, 2020 5:45 pm
RESET_9999 wrote: Wed Dec 09, 2020 5:10 pmstrange Bdinfo say its FEL.
I thought the point of using MEL, was to not take more space on the disc. But the MEL track on the Spears and munsill is also in the 2mb/s if I remember correctly. I don't think I ever noticed a mel movie with more than 100kbps bitrate
I don't know which BDInfo that is, DVDFab's? If it is that one then there's not much can be done as it is proprietary..
Also MakeMKV 1.15.3 has a bug with the Spears & Munsil video being detected as FEL: https://www.makemkv.com/forum/viewtopic ... 003#p97003
The MEL can be encoded at any bitrate, it is just recommended to be lower because it is a blank image. The EL can be played to confirm this.
Roberespa
#3857 Post by Roberespa » Wed Dec 09, 2020 8:31 pm
The television model:
OLED55B6V
The result of MakeMKV unfortunately my TV does not play the video .mkv = (
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the "cmd" command prompt and give me a .mkv or .ts video file?
Thank you so much everyone.
Waiting for your reply.
Please help me.
DaMacFunkin
#3858 Post by DaMacFunkin » Wed Dec 09, 2020 9:20 pm
Roberespa wrote: Wed Dec 09, 2020 8:31 pm The television model:
OLED55B6V
Please help me.
It has been said, Dolby Vision in MKV will not play as Dolby Vision via internal player on LG TV. Use mp4.
chros
#3859 Post by chros » Wed Dec 09, 2020 10:25 pm
quietvoid wrote: Wed Dec 09, 2020 5:45 pm The EL can be played to confirm this.
What do you mean exactly? Thanks
#3860 Post by RESET_9999 » Wed Dec 09, 2020 10:27 pm
chros wrote: Wed Dec 09, 2020 10:25 pm
if you play the EL, you can see that it's a blank grey image, therefore a MEL title.
Quietvoid is right. The LOTR are MEL with an unusually high bitrate
chros
#3861 Post by chros » Wed Dec 09, 2020 11:14 pm
RESET_9999 wrote: Wed Dec 09, 2020 10:27 pm
Cheers, didn't know this. And is the FEL coloured?
#3862 Post by RESET_9999 » Wed Dec 09, 2020 11:22 pm
chros wrote: Wed Dec 09, 2020 11:14 pm
on a FEL movie, you can see the actual movie:
MEL / FEL
Image Image
pete19
#3863 Post by pete19 » Thu Dec 10, 2020 3:36 am
RESET_9999 wrote: Wed Dec 09, 2020 10:27 pmThe LOTR are MEL with an unusually high bitrate
it's not unusual, there are quiet a few MEL titles with bitrates around 2MB... and bdinfo states FEL/MEL incorrectly, can't rely on it...
just look at the bitrate itself or the play back the EL itself...
chros
#3864 Post by chros » Thu Dec 10, 2020 8:12 am
RESET_9999 wrote: Wed Dec 09, 2020 11:22 pm on a FEL movie, you can see the actual movie
Thank you, one last question: so what's the bloody point of using 0 padded MEL (~2 Mbps) instead of the smallest one (that I saw 64 Kbps)?
I mean there must be a reason for them... :)
#3865 Post by RESET_9999 » Thu Dec 10, 2020 12:08 pm
chros wrote: Thu Dec 10, 2020 8:12 am
I have the same question... :?:
pete19 wrote: Thu Dec 10, 2020 3:36 am
Well i went back looking at 20 of the latest DV movie i added to my library and could find one (except LOTR). Must not be that usual.
pete19
#3866 Post by pete19 » Thu Dec 10, 2020 12:54 pm
RESET_9999 wrote: Thu Dec 10, 2020 12:08 pm Well i went back looking at 20 of the latest DV movie i added to my library and could find one (except LOTR). Must not be that usual.
from recent memory (~ 2MB MEL layer):
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
bluray forum has a long list, there are some
Maikel777
#3867 Post by Maikel777 » Thu Dec 10, 2020 2:50 pm
Roberespa wrote: Wed Dec 09, 2020 3:55 pm What you say about my TV:
LG OLED55B6V
That Dolby Vision does not play without being in .mp4 "is false".
This file taken from a test website shows that my TV is capable of opening Dolby Vision, at least in .ts format
I attach the link:
https://uptobox.com/q0tk0wifzm5f
I am very interested to know how this person created this .ts
Someone could explain.
I would be eternally grateful.
Thanks a lot.
Roberespa
#3868 Post by Roberespa » Thu Dec 10, 2020 4:01 pm
My LG OLED55B6V TV, if it plays .ts video files with Dolby Vision.
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the command prompt "cmd" and give me a .ts video file?
Explain how I can do it.
Please!
#3869 Post by RESET_9999 » Thu Dec 10, 2020 4:04 pm
pete19 wrote: Thu Dec 10, 2020 12:54 pm from recent memory (~ 2MB MEL layer):
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
Interesting, thanks! do you have a link to that bluray.com list?
The Hobbit movies are all below 100kbps though. And since Lawrence of Arabia is also a 2-disc movie, I wonder if it's related to the larger MEL.
Hobbit 1:
PLAYLIST REPORT:
Length: 3:02:29.438
Total Bitrate: 59.62 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 49451 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 69 kbps (0.14%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision MEL / BT.2020
DaMacFunkin
#3870 Post by DaMacFunkin » Thu Dec 10, 2020 4:47 pm
Roberespa wrote: Thu Dec 10, 2020 4:01 pm My LG OLED55B6V TV, if it plays .ts video files with Dolby Vision.
Please!
Create the mp4 as per the instructions with ac3 or DTS audio then run it through tsmuxer?
