userr wrote:
Wed Dec 09, 2020 4:48 pm
makemkv lists LOTR as BL+MEL+RPU
well, BDinfo is probably more accurate because it scans the whole movie bitrate. Makemkv thought the Spears and Munsil DV file were both MEL too.
quietvoid wrote:
Wed Dec 09, 2020 5:05 pm
LOTR 1 at least is MEL, the values in the RPU coincide with what Dolby says to recognize MEL.
strange Bdinfo say its FEL.
I thought the point of using MEL, was to not take more space on the disc. But the MEL track on the Spears and munsill is also in the 2mb/s if I remember correctly. I don't think I ever noticed a mel movie with more than 100kbps bitrate
Disc Title: The.Lord.of.the.Rings.The.Fellowship.of.the.Ring.2001.DISC1
Disc Size: 73,422,813,471 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 1:45:43.378
Total Bitrate: 91.31 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 67684 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 2099 kbps (3.01%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision FEL / BT.2020
Roberespa wrote:
Wed Dec 09, 2020 3:55 pm
That Dolby Vision does not play without being in .mp4 "is false".
No one said that. We are telling you that if your playback device is the LG B6, your best option is dual layer MP4
quietvoid
Post by quietvoid »
RESET_9999 wrote:
Wed Dec 09, 2020 5:10 pm
I don't know which BDInfo that is, DVDFab's? If it is that one then there's not much can be done as it is proprietary..
Also MakeMKV 1.15.3 has a bug with the Spears & Munsil video being detected as FEL: https://www.makemkv.com/forum/viewtopic ... 003#p97003
The MEL can be encoded at any bitrate, it is just recommended to be lower because it is a blank image. The EL can be played to confirm this.
Roberespa
Post by Roberespa »
The television model:
OLED55B6V
The result of MakeMKV unfortunately my TV does not play the video .mkv = (
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the "cmd" command prompt and give me a .mkv or .ts video file?
Thank you so much everyone.
Waiting for your reply.
Please help me.
DaMacFunkin
Post by DaMacFunkin »
Roberespa wrote:
Wed Dec 09, 2020 8:31 pm
OLED55B6V
Please help me.
It has been said, Dolby Vision in MKV will not play as Dolby Vision via internal player on LG TV. Use mp4.
chros
Post by chros »
quietvoid wrote:
Wed Dec 09, 2020 5:45 pm
What do you mean exactly? Thanks
chros wrote:
Wed Dec 09, 2020 10:25 pm
if you play the EL, you can see that it's a blank grey image, therefore a MEL title.
Quietvoid is right. The LOTR are MEL with an unusually high bitrate
chros
Post by chros »
RESET_9999 wrote:
Wed Dec 09, 2020 10:27 pm
Cheers, didn't know this. And is the FEL coloured?
chros wrote:
Wed Dec 09, 2020 11:14 pm
on a FEL movie, you can see the actual movie:
MEL / FEL
Image Image
pete19
Post by pete19 »
it's not unusual, there are quiet a few MEL titles with bitrates around 2MB... and bdinfo states FEL/MEL incorrectly, can't rely on it...
just look at the bitrate itself or the play back the EL itself...
chros
Post by chros »
RESET_9999 wrote:
Wed Dec 09, 2020 11:22 pm
Thank you, one last question: so what's the bloody point of using 0 padded MEL (~2 Mbps) instead of the smallest one (that I saw 64 Kbps)?
I mean there must be a reason for them... :)
chros wrote:
Thu Dec 10, 2020 8:12 am
I have the same question... :?:
pete19 wrote:
Thu Dec 10, 2020 3:36 am
Well i went back looking at 20 of the latest DV movie i added to my library and could find one (except LOTR). Must not be that usual.
pete19
Post by pete19 »
RESET_9999 wrote:
Thu Dec 10, 2020 12:08 pm
from recent memory (~ 2MB MEL layer):
all 3x LOTR
all 3x Hobbit
Lawrence of Arabia
bluray forum has a long list, there are some
Maikel777
Post by Maikel777 »
What you say about my TV:
LG OLED55B6V
This file taken from a test website shows that my TV is capable of opening Dolby Vision, at least in .ts format
I attach the link:
https://uptobox.com/q0tk0wifzm5f
I am very interested to know how this person created this .ts
Someone could explain.
I would be eternally grateful.
Thanks a lot.
