About a Boy
marcusfan
About a Boy
Post by marcusfan » Tue Jan 11, 2011 1:37 am
Can't seem to make it work.
setarip_old
Re: About a Boy
Post by setarip_old » Tue Jan 11, 2011 4:55 am
Hi!
Try to be a bit more specific please and describe what happens.
Is your source material an original, commercial DVD or something else?
marcusfan
Re: About a Boy
Post by marcusfan » Tue Jan 11, 2011 10:25 pm
Commercial DVD
MakeMKV v1.6.3 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/viewer/MakeMKV_log.txt
Opening files on harddrive at /Volumes/Movies/About A Boy/VIDEO_TS/
Titleset id 0 is invalid
DEBUG: Code 0 at C&L\-k/}qO".d\.sa:29394045
setarip_old
Re: About a Boy
Post by setarip_old » Wed Jan 12, 2011 6:24 am
Based on the log you've posted, it appears that your source is a rip on your hard drive, not your original, commercial DVD.
Try re-ripping your original, commercial DVD DIRECTLY (and ONLY) with MakeMKV...
marcusfan
Re: About a Boy
Post by marcusfan » Mon Feb 07, 2011 7:13 pm
Got it to work by converting to ISO using:
http://sourceforge.net/projects/aquaiso/
Then using MakeMKV.
Note choose the parent folder of the Video_TS folder while using AquaISO and not the acvtual Video_TS folder.
setarip_old
Re: About a Boy
Post by setarip_old » Mon Feb 07, 2011 10:53 pm
As I suggested in your thread regarding "A.I.":
Did you retry (without creating an .ISO image file) with MakeMKV pointed to your hard drive folder as: Opening files on harddrive at /Volumes/Movies/Artificial Inteligence/ (WITHOUT "VIDEO_TS")?
marcusfan
Re: About a Boy
Post by marcusfan » Tue Feb 08, 2011 3:19 am
Tried it. Didn't work.
Re: About a Boy
Post by mike admin » Tue Feb 08, 2011 10:06 am
