John Wick - US Version
Re: John Wick - US Version
US BL+DVD 03139821104484
00202.mpls
"John Wick_t52.mkv"
PowerDVD with Process Monitor
00202.mpls
"John Wick_t52.mkv"
This is not 100% true. It seems like Netflix is shipping two versions of this disc. The version I received from Netflix did have TrueHD audio and it did NOT have 00641.mpls. So I think it's actually the retail version. And it did have the 00202.mpls playlist with the segment map that matches the retail version.
So I read the entire thread and took notes. I believe that this is the current consensus, although your mileage may vary. This is one pain in the butt disc......
US Netflix "retail" version (with TrueHD, note that 00641.mpls does not exist on this disc)
00202.mpls
Segment map: 508,501,503,511,510,516,520,518,507,512,519,513,509,517,515,506,514,504,502,505
US Netflix non-retail version (I believe this one does not have TrueHD audio)
00641.mpls
Segment map: 505,508,507,501,512,504,520,513,517,506,515,518,510,516,503,511,519,502,514,509
US Redbox non-retail version
00641.mpls
US Retail version from Amazon
00589.mpls
US BluRay/DVD/Digital combo version at Best Buy
00202.mpls
US 4k SteelBook Version:
00202.mpls
I've come across a third Netflix disc - all segments begin with 514. The correct version is t364 (965.mpls). I believe this is the same as one of the Redbox discs.
Segments should be as follows:
514,506,517,502,505,511,508,516,519,503,520,512,510,507,504,518,509,515,501
Many thanks the everyone who posted in this thread.
Thanks for the breakdown. I think 202 is the one i was looking for.
Just incase anyone else still has some doubts, for the U.S. 4k/Blu-Ray/Digital combo Best Buy version, 00202.mpls is the correct one for the Blu-Ray.
And, if just like me, you are wondering,"where the heck is it at? I only have 203.mpls!" It is the very first one. The one with "FPL_MainFeature" next to it.
Odd mine wasn't the steelbook, but this still worked for my Bestbuy copy after manually piecing it together.
00202.mpls
00202.mpls
This is what I used on the US retail version and it works. Sequence of events is correct (I'm seen John Wick dozens of times)
Title information
Source file name: 00589.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
File name: John Wick_t174.mkv
Title information
Duration: 1:41:12
Chapters count: 16
Segment count: 20
Thanks for this thread but after reading all 8 pages I still don't understand. I am trying to rip John Wick chapter 2 blu ray and all I get is 50 huge files that all look the same. I tried to rip 1-10 to check but it seems to fail everytime. Is 4k easier to do?
John Wick (Chapter 1) Blu-Ray + Dvd + Digital from Target online (UPC 0 3139821104 4 84).
Using DVDFab Passkey and VLC, looks like it's reading 00202.mpls.
3:48:43.6367394 PM MsMpEng.exe 4352 QueryStandardInformationFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS AllocationSize: 6,144, EndOfFile: 4,402, NumberOfLinks: 1, DeletePending: False, Directory: False
3:48:43.6368043 PM MsMpEng.exe 4352 ReadFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS Offset: 0, Length: 4,402, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
3:48:43.8461743 PM vlc.exe 3108 QueryStandardInformationFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS AllocationSize: 6,144, EndOfFile: 4,402, NumberOfLinks: 1, DeletePending: False, Directory: False
3:48:43.8462139 PM vlc.exe 3108 ReadFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS Offset: 0, Length: 4,402, Priority: Normal
3:48:43.8462864 PM vlc.exe 3108 ReadFile E:\BDMV\PLAYLIST\00202.mpls END OF FILE Offset: 4,402, Length: 24,576, Priority: Normal
3:48:43.8463808 PM vlc.exe 3108 ReadFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS Offset: 4,398, Length: 4, Priority: Normal
3:48:43.8464110 PM vlc.exe 3108 ReadFile E:\BDMV\PLAYLIST\00202.mpls END OF FILE Offset: 4,402, Length: 28,672, Priority: Normal
3:48:43.8464313 PM vlc.exe 3108 CloseFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS
3:48:45.4432866 PM vlc.exe 3108 CreateFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, Write, AllocationSize: n/a, OpenResult: Opened
3:48:45.4443176 PM vlc.exe 3108 QueryStandardInformationFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS AllocationSize: 6,144, EndOfFile: 4,402, NumberOfLinks: 1, DeletePending: False, Directory: False
3:48:45.4443378 PM vlc.exe 3108 ReadFile E:\BDMV\PLAYLIST\00202.mpls SUCCESS Offset: 0, Length: 4,402, Priority: Normal
Title information
Comment: FPL_MainFeature
Source file name: 00202.mpls
Duration: 1:41:12
Chapters count: 16
Segment count: 20
File name: John Wick-FPL_MainFeature_t00.mkv
