#796 Post by MartyMcNuts » Sat Dec 05, 2020 1:50 am
shaferandrew wrote: Fri Dec 04, 2020 9:44 pm Hi all,
I wanted to thank everyone for their great advice in here. I bought a WH14NS40 from Amazon this week and it arrived today with a mfg date of July 2020 and the 1.05 firmware. I used the SDFtool to flash it to HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin (checking enc?). I then rebooted and used the tool to flash it to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin (in the "old" directory, also had to check enc? to flash correctly). I rebooted. It now reports itself as a WH16NS60 in Windows/MakeMKV/etc. I have successfully used it to rip Blu-rays. I do not have a UHD disc to check that functionality but I assume that should work (because of the 1.02 firmware?).
UHD should work.
vseven
#797 Post by vseven » Sat Dec 05, 2020 3:39 am
MartyMcNuts wrote: Sat Dec 05, 2020 1:49 am Don't know about firmware 1.02. I normally flash BP60NB10_1.00-MK.
Yeah, I re-read the first post and had some trouble flashing it to anything else but eventually got it to take that firmware. I'll test it with a UHD when I find one but with that said I have one of the "friendly" drives already on order (I needed a second anyway).
Fuckman4
#798 Post by Fuckman4 » Tue Dec 08, 2020 11:30 pm
Many thanks for this post’s everything!
I have an HP BU40N.
It can neither rip a UHD disc (because DVDFab and DeUHD don’t support HP version’s FW until now) nor play UHD discs via PowerDVD (because PowerDVD doesn’t support it either).
After I flashed it into LG BU40N original FW by this post’s stuff, both playing and ripping work now!
#799 Post by MartyMcNuts » Wed Dec 09, 2020 3:03 am
Fuckman4 wrote: Tue Dec 08, 2020 11:30 pm Many thanks for this post’s everything!
I have an HP BU40N.
Awesome!!
agent47
#800 Post by agent47 » Wed Dec 09, 2020 6:04 pm
Hi All
I've acquired a very old ASUS Bluray external USB drive - a SBC-06D1S-U working absolutely fine for backing up blurays on my windows 10 machine - but since i'm new to all this i'm wondering if i can take it to the next level by backing up UHD blurays. I came across this thread about flashing firmware - however it doesn't appear that firmware is available to download for my external drive on the ASUS website. I'm wondering if anyone could help guide me through the process in this case? Or of course advise whether I can't rip UHD's with this drive!
Regards
Agent47
#801 Post by Woodstock » Wed Dec 09, 2020 7:44 pm
Load MakeMKV and let it tell you if flashing is possible.
The -U drives, though, are probably NOT going to support BD XL, so they aren't going to be UHD-friendly.
rob18014
#802 Post by rob18014 » Wed Dec 09, 2020 8:00 pm
(Just bought the Blu Ray burner) I just want to thank everyone who worked on the CFW, and the flasher. I did the latest update on Asus site 3.10 for the Asus BW-16DHT then flashed 3.10 CFW.. Then 3.01 to 3.02.. It was simple and easy and I'm ripping UHD discs as I type. :D Thanks again, Rob
agent47
#803 Post by agent47 » Wed Dec 09, 2020 8:54 pm
Thanks for the reply
Have loaded up makemkv and I can't see where it says it's flashing is possible so I'm going to assume it isn't possible. It doesn't even give a firmware version of the drive so guessing it might not even have firmware.
agent47
#804 Post by agent47 » Wed Dec 09, 2020 10:26 pm
rob18014 wrote: Wed Dec 09, 2020 8:00 pm (Just bought the Blu Ray burner) I just want to thank everyone who worked on the CFW, and the flasher. I did the latest update on Asus site 3.10 for the Asus BW-16DHT then flashed 3.10 CFW.. Then 3.01 to 3.02.. It was simple and easy and I'm ripping UHD discs as I type. :D Thanks again, Rob
hiya - looks like i'm in the market for one too - it's the internal ASUS BW-16D1HT you bought?
rob18014
#805 Post by rob18014 » Thu Dec 10, 2020 12:21 am
Yes it is.. Got ya jong! :D
jonghotti
#806 Post by jonghotti » Thu Dec 10, 2020 4:13 am
Or you could support the community by buying from one of the sellers found here: https://www.makemkv.com/forum/viewforum.php?f=20 we've sales professionals that cover every square inch of the globe :)
taztheman
#807 Post by taztheman » Mon Dec 14, 2020 4:41 pm
This forum is awesome and I've learned so much but I have an issue I cannot seem to find. I have a WH16NS40 that is brand new from Amazon with 1.05 on it. Tried the LG flasher. Checksum error. Tried the ASUS flasher, error #5. After reading positive results I tried the SDF flasher with the MK version of my firmware no luck. Then tried the SDF flasher with HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440 and also no luck. I made sure to check the "enc?" option. I get "command produced error code 0x8f05c103". I have the 5.25" drive in a OWC Mercury Pro external enclosure. Anybody have any advice for me. I feel like I have tried about every option on these forums (but I'm sure I've missed something). The drive works fine without UHD but I have a ton of UHD discs.
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLJK8HI1041
Highest AACS version: 70
Harware support: Yes
Firmware support: No
Firmware version: 1.05
zapultin
#808 Post by zapultin » Fri Dec 18, 2020 2:04 pm
Hi everybody. Just got the Asus 16D1HT manufactured August 2020 with firmware 3.10.
After researching I confirm that I was able to flash the MK firmware like this:
- download modified Asus flasher (out of this post)
- download the MK firmware https://www.makemkv.com/forum/viewtopic ... 19&t=19113
Select the MK firmware in the Asus flasher, done! Reading UHD disk as I write this post ;)
The SDFtool flasher produced an error 0x8f05c103 and did not do the job.
And last but not least... I didn't read everything close enough which made me brick my old drive. It is a BH16NS40 manufactured June 2014. If anyone has tips how to get it to work again... but I needed a new drive anyway as the old one, to my understanding now, will never read UHDs. Just a shame that now I have to throw it away...
tibopix
#809 Post by tibopix » Wed Dec 23, 2020 2:10 pm
Hello everyone and thank you for this great forum,
I just got an Archgon MD-8107-U3 UHD drive (made in Taiwan) with the below info extracted from MakeMKV.
I've tried flashing it using ASUS_ODD_FW_Changer but the app wouldn't even launch.
After I double click on it, a window slightly flashes on screen, then the ASUS_ODD_FW_Changer app just vanishes from the folder (Windows 10 Pro).
Any help would be greatly appreciated :-D
Informations lecteur
Nom du lecteur SE : \Device\CdRom0
Profil actuel : BD-ROM
Fabricant : HL-DT-ST
Produit : BD-RE BU40N
Révision : 1.01
Numéro de série : XXXXXXXXXXXXX
Date micrologiciel : 2119-10-16 10:32
Marqueurs d'encryptage bus : 1F
Version AACS la plus haute : 68
Firmware version: 1.01
rob18014
#810 Post by rob18014 » Wed Dec 23, 2020 7:39 pm
Windows 10 may be picking it up as malware. Turn off the Windows 10 anti- malware/viris protection until you complete the flash. The (.exe) should not be disappearing. (Flasher) if you have other Antivirus turn it off as well until the flash is complete.
