Everlasting Moments (2008)
Kappabear
Post by Kappabear » Wed Dec 09, 2020 5:43 pm
I'm trying to rip/convert the movie Everlasting Moments (2008), so that I can add it to my Plex server, but I'm encountering errors, and I'm not exactly sure why. It appears that they could be hardware related, but I'm not positive. The edge of the disk is slightly beaten up, and if I run my fingernail along it, it gets caught in some of the chips. I took a black marker pen, and went along the edge of the DVD, and that helped a bit, as MakeMKV was able to read about 250 MB of data before it came to crashing halt. Since then, MakeMKV reads 0 MB of data, and after 10 minutes or so, immediately errors out. The DVD appears to play perfectly in Apple's DVD player, but instantly fails in MakeMKV.
Debug log started at Wed Dec  9 17:09:31 2020 , written by MakeMKV v1.15.3 darwin(x64-release)
001005:0000 MakeMKV v1.15.3 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/user/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.64.1/(SecureTransport) LibreSSL/2.8.3 (x86_64-apple-darwin19.0) , proxy server not set.
002010:0000 Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
001003:0020 DEBUG: Code 0 at F\*z(O*2XK(Bc\ko:29407201
No  SDF v07d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
No auto SDF v07d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
DEBUG: Code 0 at n!ysZ^DeG<7@Ht`+Y:213132284
DEBUG: Code 0 at `PDP'Y<E4nRZuR)7:121268604
SDF id v07d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
003028:0000 Title #2 was added (1 cell(s), 0:02:07)
003028:0000 Title #3 was added (19 cell(s), 2:11:05)
003025:0000 Title #4 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file:///Users/user/Movies/Rips
001003:0020 DEBUG: Code 1073741829 at r+Nlgy+&TKr9Y,Mo:213130559
001003:0020 DEBUG: Code 100941314 at `PDP'Y<E4nRZuR)7:213139667
001003:0020 DEBUG: Code 100941314 at r+Nlgy+&TKr9Y,Mo:213130559
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02' at offset '21635072'
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk9' at offset '21635072'
DEBUG: Code 1073741829 at ui]{;3u:7O4yrt7iLp:121263084
001003:0020 DEBUG: Code 1073741829 at ui]{;3u:7O4yrt7iLp:29395149
DEBUG: Code 100941314 at ui]{;3u:7O4yrt7iLp:121263084
001003:0020 DEBUG: Code 100941314 at ui]{;3u:7O4yrt7iLp:29395149
001003:0020 DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:29395471
001003:0020 DEBUG: Code 0 at `INs-e#4P^u9m;olHZp:29393562
001003:0020 DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:213131157
001003:0020 DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:121262647
001003:0020 DEBUG: Code 10564 at i/KyO`_OY#FKb6Mwy:rI:121261773
001003:0020 DEBUG: Code 0 at F2KY5iV:#oS,h:x=5Kk:213132491
001003:0020 DEBUG: Code 0 at Tk_-[@5B#==Kelrv;&y41:213137091
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed /Users/user/Movies/Rips/title_t01.mkv
ch_0          19981962000 0
ch_1          20522502000 0
ch_2          21063042000 0
ch_3          21603582000 0
ch_4          22144122000 0
ch_5          22594572000 0
ch_6          23045022000 0
ch_7          23891868000 1
mt=0x7f9e96e26d00 n=3
s=0 n=21 o=18894848
    0   7465 000011    23045022000       36036000 934DB2DC 000001B32D01E03416D3E3821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808080808090909090909090909090909090909090909090909090A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A
    0    288 000018    22954932000       36036000 E49BF2F1 00000100001FFFFBB8000001B585465BD9800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000018    22990968000       54054000 0FCBD97E 00000100005FFFFBB8000001B586554BDB800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23135112000       36036000 6EEE04D7 000001000117FFFB80000001B5865FFBD9800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23081058000       54054000 8FA985B1 0000010000DFFFFBB8000001B585465B5B800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23261238000       54054000 05DC7397 0000010001D7FFFB80000001B5865FFB5B800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23171148000       54054000 61FCE973 00000100015FFFFBB8000001B585465BDB800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000018    23225202000       36036000 967CFC8C 00000100019FFFFBB8000001B586554B59800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23351328000       54054000 B89F7B35 000001000257FFFB80000001B5865FFBDB800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23315292000       36036000 B78D9691 00000100021FFFFBB8000001B585465BD9800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0   7465 000011    23441418000       54054000 9DB79B3C 000001B32D01E03416D3E3821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808080808090909090909090909090909090909090909090909090A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A
    0    288 000018    23405382000       36036000 0109E5D8 00000100001FFFFBB8000001B585465B59800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23585562000       36036000 8B7C13FE 000001000117FFFB80000001B5865FFB59800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23495472000       36036000 1DD9DBA8 00000100009FFFFBB8000001B585465BD9800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000018    23531508000       54054000 F689F027 0000010000DFFFFBB8000001B586554BDB800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23675652000       36036000 97AC2D8E 000001000197FFFB80000001B5865FFBD9800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23621598000       54054000 846EFE5A 00000100015FFFFBB8000001B585465B5B800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000010    23801778000       54054000 5D0D6C1C 000001000257FFFB80000001B5865FFB5B800000010112701014700000010212701014700000010312701014700000010412701014700000010512701014700000010612701014700000010712701014700000010812701014700000010912701014700000010A12701014700000010B12701014700000010C12701014700000
    0    288 000018    23711688000       54054000 98BEC02A 0000010001DFFFFBB8000001B585465BDB800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0    288 000018    23765742000       36036000 CEADE307 00000100021FFFFBB8000001B586554B59800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
    0   7465 000013    23891868000       54054000 E0F0C60A 000001B32D01E03416D3E3821010101210121616161616161A181A1A1A1A1A1A1A1A1A1A1A1C1C1C2222221C1C1C1A1A1C1C2020222224262422222222262628282830302E2E38383A444453080808080808090909090909090909090909090909090909090909090A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A0A
s=1 n=1 o=18870272
    1   1792 000001    23051520000       34560000 EED3F8CF 0B770A901E40E1FC18C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
s=2 n=0 o=21635072
mt=0x7f9e96e28030 n=3
s=0 n=0 o=18894848
s=1 n=32 o=18870272
    1   1792 002001    23086080000       34560000 490D9806 0B770A901E40E1FC18C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23120640000       34560000 0A3A7D25 0B770A901E40E1FC18C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23155200000       34560000 4BC1663E 0B770A901E40E1FC18C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23189760000       34560000 1FE618F5 0B7739BA1E40E1FC1CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23224320000       34560000 4C6E7FA6 0B7739BA1E40E1FC1CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23258880000       34560000 42AB8E8A 0B7739BA1E40E1FC1CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23293440000       34560000 1FD01B62 0B7739BA1E40E1FC1CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23328000000       34560000 AD27BA82 0B77B9391E40E1FC20C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23362560000       34560000 D26ECEBA 0B77B9391E40E1FC20C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23397120000       34560000 D70AA516 0B77B9391E40E1FC20C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23431680000       34560000 4980DA8F 0B77B9391E40E1FC20C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23466240000       34560000 90C24C28 0B778A131E40E1FC24C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23500800000       34560000 1FE3A2C8 0B778A131E40E1FC24C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23535360000       34560000 1DDD7D7F 0B778A131E40E1FC24C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23569920000       34560000 A88AC75F 0B778A131E40E1FC24C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23604480000       34560000 9D563B60 0B778A131E40E1FC24C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23639040000       34560000 9CEA7CE6 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23673600000       34560000 C52CFBBE 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23708160000       34560000 2666D041 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23742720000       34560000 96D8B9AE 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23777280000       34560000 2C15BF3A 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23811840000       34560000 2242689D 0B77DF6D1E40E1FC28C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23846400000       34560000 68302B0C 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23880960000       34560000 DD6DF452 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23915520000       34560000 35C13F00 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23950080000       34560000 A0C4523C 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    23984640000       34560000 1FF779C3 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    24019200000       34560000 20878231 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    24053760000       34560000 9DF8FD6C 0B77EC471E40E1FC2CC03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    24088320000       34560000 49908BFA 0B7775911E40E1FC30C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    24122880000       34560000 3959F0D6 0B7775911E40E1FC30C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
    1   1792 002001    24157440000       34560000 31C4EEA5 0B7716C51E40E1FC30C03EFF5970808210104202084041080815578F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF3ABE7CF9F3CE0F9F3E7CF9F3E7CF9D3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9ED6AEF9F3E7CF9F3E7DFFCDAA9F3CD8567BE7CA9F3E7CF9F3E74F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7
s=2 n=0 o=21635072
mt=0x7f9e96e32f70 n=3
s=0 n=1 o=18894848
    0    288 000018    23855832000       36036000 E49BF2F1 00000100001FFFFBB8000001B585465BD9800000010112B01014B00000010212B01014B00000010312B01014B00000010412B01014B00000010512B01014B00000010612B01014B00000010712B01014B00000010812B01014B00000010912B01014B00000010A12B01014B00000010B12B01014B00000010C12B01014B00000
s=1 n=1 o=18870272
    1   1792 002001    24192000000       34560000 60F4D0DD 0B77415B1E40E1FC30C03EFF5970808210104202084041080815978F9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFF2E95AEF6BBE7CA9B3E7CF9F3E7CF9F3E7CF9F3E7CF9F3CE0F9ED77CE9E7079B0B3E2B597569D5A7BE6CF6BBCE1FFCE2A9D3CE0F383E7CA6BBCE0F9F3E74F8B3E7CF9F367CF9F2A54F9E707CF953E54F9E687
s=2 n=0 o=21635072
005003:0000 Failed to save title 1 to file /Users/user/Movies/Rips/title_t01.mkv
002023:0000 Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06043E02 count=11 name=Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Encountered 6 unclassified errors
error=0x40000005 count=6 name=Posix error - Input/output error
005004:0080 0 titles saved, 1 failed
001003:0020 DEBUG: Code 268435459 at NE5|W}%{?VZR}k10MDv663q,Us#:213130789
001003:0020 DEBUG: Code 2281701379 at `PDP'Y<E4nRZuR)7:29399197
Application exited at Wed Dec  9 17:31:21 2020
preserve
Re: Everlasting Moments (2008)
Post by preserve » Mon Dec 14, 2020 8:44 am
^ That’s probably the main issue. Even if another application can play the disc, it doesn’t mean MakeMKV can rip it, as other applications may skip past read errors but MakeMKV won’t, to provide a perfect rip.
The troubleshooting mentioned here may be relevant:
viewtopic.php?f=8&t=15055
Using: ASUS BW-16D1HT 3.00
