DaMacFunkin
#3856 Post by DaMacFunkin » Wed Dec 09, 2020 3:07 pm
RESET_9999 wrote:
Wed Dec 09, 2020 12:05 pm
Roberespa wrote:
Wed Dec 09, 2020 11:46 am
Inside the LG menu.
The television model says:
OLED55B6V-Z
and at the end an interesting fact.
Dolby Vision 0.9.0
I also tried MakeMKV v1.15.3 but the TV won't open it.
Demomento only worked (opened it) with Dolby Vision in .mp4
Thanks for answering me.
I wait your answer.
I don't know if the problem will be the file size ... = (
you don't need a ts/mkv file if you play them in your LG B6. stick with the mp4muxer.
DaMacFunkin wrote:
Wed Dec 09, 2020 6:07 am
Hi, you don’t say what your playback device is?
TLOTR and The Hobbit are MEL so the easiest way to create Dolby Vision MKV is Makemkv.
LOTR are FEL DV
Sorry only ripped The Hobbits upto now and they are MEL, blu-ray.com listed TLOTR as MEL also so didn’t have a reason to question it.
Roberespa
#3857 Post by Roberespa » Wed Dec 09, 2020 3:55 pm
What you say about my TV:
LG OLED55B6V
That Dolby Vision does not play without being in .mp4 "is false".
This file taken from a test website shows that my TV is capable of opening Dolby Vision, at least in .ts format
I attach the link:
https://uptobox.com/q0tk0wifzm5f
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the "cmd" command prompt and give me a .mkv or .ts video file?
Thank you so much everyone.
Waiting for your reply.
userr
#3858 Post by userr » Wed Dec 09, 2020 4:00 pm
Inside the LG menu.
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
LOTR are FEL DV
How do we even know if its "MEL" or "FEL" when theres a bitrate of roughly 2Mb/s like in LOTR?
#3859 Post by RESET_9999 » Wed Dec 09, 2020 4:32 pm
LOTR are FEL DV
MEL movies bitrate are in 100kbps or less.
also a scan with BDinfo will tell you. Makemkv tells you that info too.
PLAYLIST REPORT:
Length: 1:46:39.184
Total Bitrate: 88.47 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 64757 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 2098 kbps (3.14%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision FEL / BT.2020
Marvin
#3860 Post by Marvin » Wed Dec 09, 2020 4:44 pm
~2Mbit/s FEL is in fact MEL that is padded. It can be easily verified when using tools to extract the EL+RPU and looking at it in an hex editor. Or even better, try compressing that "FEL" layer and in case of LOTR the 2GB+ file will compress to about 6MB.
More information about the 2Mbit padding is in the first post of https://forum.blu-ray.com/showthread.php?t=276448
What is strange is that LOTR is padded MEL to 2Mbit/s but Hobbits are pure MEL with no padding.
userr
#3861 Post by userr » Wed Dec 09, 2020 4:48 pm
PLAYLIST REPORT:
Length: 1:46:39.184
VIDEO:
makemkv lists LOTR as BL+MEL+RPU
quietvoid
#3862 Post by quietvoid » Wed Dec 09, 2020 5:05 pm
LOTR 1 at least is MEL, the values in the RPU coincide with what Dolby says to recognize MEL.
#3863 Post by RESET_9999 » Wed Dec 09, 2020 5:08 pm
well, BDinfo is probably more accurate because it scans the whole movie bitrate. Makemkv thought the Spears and Munsil DV file were both MEL too.
#3864 Post by RESET_9999 » Wed Dec 09, 2020 5:10 pm
strange Bdinfo say its FEL.
I thought the point of using MEL, was to not take more space on the disc. But the MEL track on the Spears and munsill is also in the 2mb/s if I remember correctly. I don't think I ever noticed a mel movie with more than 100kbps bitrate
Disc Title: The.Lord.of.the.Rings.The.Fellowship.of.the.Ring.2001.DISC1
Disc Size: 73,422,813,471 bytes
Protection: AACS2
Extras: Ultra HD, BD-Java
BDInfo: 0.7.5.9
PLAYLIST REPORT:
Length: 1:45:43.378
Total Bitrate: 91.31 Mbps
VIDEO:
MPEG-H HEVC Video 67684 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 2099 kbps (3.01%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision FEL / BT.2020
#3865 Post by RESET_9999 » Wed Dec 09, 2020 5:17 pm
No one said that. We are telling you that if your playback device is the LG B6, your best option is dual layer MP4
quietvoid
#3866 Post by quietvoid » Wed Dec 09, 2020 5:45 pm
I don't know which BDInfo that is, DVDFab's? If it is that one then there's not much can be done as it is proprietary..
Also MakeMKV 1.15.3 has a bug with the Spears & Munsil video being detected as FEL: https://www.makemkv.com/forum/viewtopic ... 003#p97003
The MEL can be encoded at any bitrate, it is just recommended to be lower because it is a blank image. The EL can be played to confirm this.
Roberespa
#3867 Post by Roberespa » Wed Dec 09, 2020 8:31 pm
The television model:
OLED55B6V
The result of MakeMKV unfortunately my TV does not play the video .mkv = (
Please help me.
DaMacFunkin
#3868 Post by DaMacFunkin » Wed Dec 09, 2020 9:20 pm
OLED55B6V
Please help me.
It has been said, Dolby Vision in MKV will not play as Dolby Vision via internal player on LG TV. Use mp4.
chros
#3869 Post by chros » Wed Dec 09, 2020 10:25 pm
What do you mean exactly? Thanks
#3870 Post by RESET_9999 » Wed Dec 09, 2020 10:27 pm
if you play the EL, you can see that it's a blank grey image, therefore a MEL title.
Quietvoid is right. The LOTR are MEL with an unusually high bitrate
