Roberespa
Post by Roberespa »
I have tried to create the Lord of the Rings with all the possible forms that are offered to me in the forum, the only one that worked was mp4.
With it I have Dolby Vision.
Just one more thing (if you are so kind to answer me):
Hevc1 and hevc2 can be merged directly from the system symbol to .mkv
If so, please send me the command. I'm desperate.
Thank you very much in advance.
Sincerely:
-Rober.
DaMacFunkin
Post by DaMacFunkin »
Roberespa wrote: Tue Dec 08, 2020 11:31 pm I have tried to create the Lord of the Rings with all the possible forms that are offered to me in the forum, the only one that worked was mp4.
Sincerely:
-Rober.
Hi, you don’t say what your playback device is?
TLOTR and The Hobbit are MEL so the easiest way to create Dolby Vision MKV is Makemkv.
Roberespa
Post by Roberespa »
Interestingly when I use:
MUX_AND_CONVERT_TO_MEL
or
MUX_AND_CONVERT_TO_PROFILE_81
and with tsMuxeR I convert it to .ts or .m2ts in Mediainfo no trace of Dolby Vision. And the TV opens it as HDR but not a trace of Dolby Vision.
General
Nombre completo : T:\El Señor de los Anillos La Comunidad del Anillo V.E 2001 UHD-REMUX Dolby Vision HDR10\El Señor de los Anillos La Comunidad del Anillo V.E 2001 UHD-REMUX Dolby Vision HDR10.ts
Formato : MPEG-TS
Tamaño de archivo : 57,8 GiB
Duración : 1 h 45 min
Modo de tasa de bits : Variable
Tasa de bits general : 78,3 Mb/s
Tasa de bits genral máxima : 35,5 Mb/s
Vídeo
ID menú : 1 (0x1)
Formato : HEVC
Formato/Info : High Efficiency Video Coding
Formato del perfil : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
ID códec : 6
Ancho : 3 840 píxeles
Alto : 2 160 píxeles
Relación de aspecto : 16:9
Velocidad de fotogramas : 23,976 (24000/1001) FPS
Espacio de color : YUV
Submuestreo croma : 4:2:0 (Type 2)
Profundidad bits : 10 bits
Rango de color : Limited
Colores primarios : BT.2020
Características transferencia : PQ
Coeficientes matriz : BT.2020 non-constant
Principios color monitor masterización : Display P3
Luminancia monitor masterización : min: 0.0050 cd/m2, max: 4000 cd/m2
Nivel ligero contenido máximo : 602 cd/m2
Nivel ligero fotograma medio máximo : 184 cd/m2
Roberespa
Post by Roberespa »
DaMacFunkin wrote: Wed Dec 09, 2020 6:07 am
Sincerely:
-Rober.
Inside the LG menu.
The television model says:
OLED55B6V-Z
and at the end an interesting fact.
Dolby Vision 0.9.0
I also tried MakeMKV v1.15.3 but the TV won't open it.
Demomento only worked (opened it) with Dolby Vision in .mp4
Thanks for answering me.
I wait your answer.
I don't know if the problem will be the file size ... = (
Roberespa wrote: Wed Dec 09, 2020 11:46 am Inside the LG menu.
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
you don't need a ts/mkv file if you play them in your LG B6. stick with the mp4muxer.
LOTR are [s] FEL DV [/s]
userr
Post by userr »
lexyz wrote: Tue Dec 08, 2020 8:26 pm
Doosethemoose wrote: Tue Dec 08, 2020 7:01 pm Sony X900f
Is there a lossless way to get my TV to properly display DV profile 7 content?
Sadly not possible. XF90 plays properly only DoVi p5
XH90 is the only Sony TV plays DoVi 5, 7 MEL and 8
what do you mean "only sony tv", if an external device plays profile7 mkv the tv displays what the external device sends
lexyz
Post by lexyz »
userr wrote: Wed Dec 09, 2020 2:00 pm what do you mean "only sony tv", if an external device plays profile7 mkv the tv displays what the external device sends
I mean dolby vision playback by internal TV Media player or Plex without external device
DaMacFunkin
Sincerely:
-Rober.
Inside the LG menu.
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
Your tv will not play DV from mkv.
DaMacFunkin
RESET_9999 wrote: Wed Dec 09, 2020 12:05 pm
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
LOTR are FEL DV
Sorry only ripped The Hobbits upto now and they are MEL, blu-ray.com listed TLOTR as MEL also so didn’t have a reason to question it.
Roberespa
Post by Roberespa »
What you say about my TV:
LG OLED55B6V
That Dolby Vision does not play without being in .mp4 "is false".
This file taken from a test website shows that my TV is capable of opening Dolby Vision, at least in .ts format
I attach the link:
https://uptobox.com/q0tk0wifzm5f
Returning to my question. Is there a command to merge Hevc1 and hevc2 from the "cmd" command prompt and give me a .mkv or .ts video file?
Thank you so much everyone.
Waiting for your reply.
userr
Post by userr »
DaMacFunkin wrote: Wed Dec 09, 2020 3:07 pm
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
LOTR are FEL DV
How do we even know if its "MEL" or "FEL" when theres a bitrate of roughly 2Mb/s like in LOTR?
userr wrote: Wed Dec 09, 2020 4:00 pm
LOTR are FEL DV
MEL movies bitrate are in 100kbps or less.
also a scan with BDinfo will tell you. Makemkv tells you that info too.
PLAYLIST REPORT:
Length: 1:46:39.184
Total Bitrate: 88.47 Mbps
Indicates included stream hidden by this playlist.
VIDEO:
Codec Bitrate Description
MPEG-H HEVC Video 64757 kbps 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / HDR10 / BT.2020
* MPEG-H HEVC Video 2098 kbps (3.14%) 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 4000nits / Dolby Vision FEL / BT.2020
Marvin
Post by Marvin »
~2Mbit/s FEL is in fact MEL that is padded. It can be easily verified when using tools to extract the EL+RPU and looking at it in an hex editor. Or even better, try compressing that "FEL" layer and in case of LOTR the 2GB+ file will compress to about 6MB.
More information about the 2Mbit padding is in the first post of https://forum.blu-ray.com/showthread.php?t=276448
What is strange is that LOTR is padded MEL to 2Mbit/s but Hobbits are pure MEL with no padding.
userr
Post by userr »
RESET_9999 wrote: Wed Dec 09, 2020 4:32 pm
PLAYLIST REPORT:
Length: 1:46:39.184
VIDEO:
makemkv lists LOTR as BL+MEL+RPU
quietvoid
Post by quietvoid »
LOTR 1 at least is MEL, the values in the RPU coincide with what Dolby says to recognize MEL.
