Cannot Rip ANY Disney Blu-ray Disc
moritasan2040
#1 Post by moritasan2040 » Wed Dec 09, 2020 6:23 am
Hello. I can use MakeMKV to make back-ups of all my DVDs and BDs from all regions and companies except...any BDs by Disney. I've looked into other posts of similar problems on here, but their problems seemed a bit different. For all my Disney BDs, title_t00.mkv is always ripped improperly, while all the others work fine. I've tried Hercules, The Lion King, and Aladdin. For the first two, it's a problem cuz that file is the movie itself, but luckily that wasn't the case for Hercules. My drive is a brand-new Pioneer BD-RW BDR-212M. It's wonderful, and rips all the discs I had trouble with before (except for these three). And yet...
MakeMKV v1.15.3 win(x64-release) started
AACS directory not present, assuming unencrypted disc
File 00800.mpls was added as title #0
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #1
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00880.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00881.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00884.m2ts was added as title #2
Title #00888.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00889.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00890.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00891.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00903.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00912.m2ts was added as title #3
Title #00914.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00915.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00916.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00918.m2ts was added as title #4
Title #00919.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00920.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00921.m2ts was added as title #5
Title #00923.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00925.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00926.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00927.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 6 titles into directory F:/Videoes/Fresh Rips/Hercules
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00883.m2ts' at offset '13094486016'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '13094486016'
Failed to save title 0 to file F:/Videoes/Fresh Rips/Hercules/Hercules_t00.mkv
AV synchronization issues were found in file 'Hercules_t02.mkv' (title #3)
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
Forced subtitles track #11 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'Hercules_t05.mkv' (title #6)
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
5 titles saved, 1 failed
preserve
Re: Cannot Rip ANY Disney Blu-ray Disc
#2 Post by preserve » Wed Dec 09, 2020 8:21 am
From the log, you can see that MakeMKV encountered read errors on that disc.
In addition to the link given in the log file for read errors, this sticky thread also addresses your question:
viewtopic.php?f=8&t=15055
Using: ASUS BW-16D1HT 3.00
#3 Post by Woodstock » Wed Dec 09, 2020 1:56 pm
Is this a log from processing a backup already on your hard drive, or from a direct read of the BD? The lack of an AACS directory would indicate an unencrypted backup.
If from the BD, what type drive (that's missing from the log) ?
Read errors from your hard drive are a different sort of problem than from the optical drive.
moritasan2040
#4 Post by moritasan2040 » Thu Dec 10, 2020 5:28 am
preserve wrote: Wed Dec 09, 2020 8:21 am From the log, you can see that MakeMKV encountered read errors on that disc.
I read that thread, but the specific errors, "Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR" and "OS error - STATUS_DEVICE_DATA_ERROR", I couldn't find information about in that thread.
I did, however, read MakeMKV.com's Error Classification page, but it just says it's either a damaged disc or a damaged drive, but like I said, I went and bought a brand-new drive solely becuz they wouldn't rip, and they were all brand-new sealed discs. And the fact that it's all three, not just one disc, and that it's only the ones by Disney, is a bit weird.
Woodstock wrote: Wed Dec 09, 2020 1:56 pm Is this a log from processing a backup already on your hard drive, or from a direct read of the BD? The lack of an AACS directory would indicate an unencrypted backup.
I'm doing a direct read of the BD. It's a brand-new Pioneer BD-RW BDR-212M.
preserve
#5 Post by preserve » Thu Dec 10, 2020 2:11 pm
moritasan2040 wrote: Thu Dec 10, 2020 5:28 amAnd the fact that it's all three, not just one disc, and that it's only the ones by Disney, is a bit weird.
Yeah, it is a bit weird. Never had any problems with Disney myself.
oreotookie
#6 Post by oreotookie » Wed Dec 30, 2020 6:17 pm
I've had the SAME issue. I can't seem to get any Disney Blu-ray to rip. Disks are cleaned and they play just fine. Frustrated to not find any answers.
preserve
#7 Post by preserve » Thu Dec 31, 2020 12:43 am
Have you tried using another drive? Maybe an LG or an ASUS instead of a Pioneer?
Ice4D
#8 Post by Ice4D » Tue Jan 02, 2024 11:39 am
Hi, Did anyone manage to rip Aladdin 2019 successfully without glitches? I am in the process of buying a drive to rip a Blu-ray disc of Aladdin to use for an event, but it will be timecoded with lighting, so the Reaper DAW needs to be able to play it.
If a quality UHD movie cannot be achieved I have to look at alternative options.
I only plan to rip that movie and later on, one other: The Greatest Showman, so don't want to fork out money for something I will use rarely.
A friend of mine obtained the movie from a download but we now find it has several milky white glitches for a few seconds, which spoils the movie, so the next step is to see if I can make a decent job of it.
Any help, pointers, guidance, tips would be appreciated. Thanks
