Post by RESET_9999 » Tue Dec 08, 2020 12:11 pm
TickTock wrote:
Tue Dec 08, 2020 8:49 am
The x700's media player outputs DTS-HD as LPCM. If you click on the "Display" button on the x700's remote during playback it will list the audio format of the film. For DTS-HD it reports DTS-HD, the number of channels, the sampling rate and the current bit rate. My AVR reports the sound as PCM multi in and lists the correct number of channels being used.
My Denon AVR correctly plays/reports DTS-HD, not PCM. Not sure why it's different on your setup
TickTock
Post by TickTock » Tue Dec 08, 2020 2:58 pm
PlatypusW wrote:
Tue Dec 08, 2020 11:42 am
No I didn’t notice anything like that, but then again I was trying it on an x800 which would have been completely ignoring the secondary Dolby vision track. I’ll try again when I get my x700 :D
I only did one quick test, but I think you may be right. As I had deleted the files I used to test before, I created two new 1GB split clips and did the following:
lotr-split1gb - Dolby Vision turned off on the x700 - the file plays perfectly and finishes at the correct time. It then automatically started
to play the second split file perfectly.
lotr-split1gb - Dolby Vision turned on, on the x700 - the file plays perfectly but behaves the same as before at the end. It continues increasing the duration while stuck on the last frame. I pressed stop and the duration stopped increasing but the player was still stuck on the last frame and unresponsive. I decided to wait and after a minute or so I pressed the stop and off button, the screen went black but the player's led was still on. After a few minutes I turned it off at the mains.
I also tested a cut clip again, the plan was to test the clip with Dolby Vision set to off and then on, on the x700 to see if it made a difference with the green overlay. This time the cut clip played fine with Dolby Vision turned on, I'm now wondering if I forgot to restart the player before playing the first cut clip, in which case that would be normal.
I just changed "Digital Music Enhancer" to off and now my AVR reports the signal as DTS-HD Master and sound as DTS-HD + Neural:X (ceiling speakers). Thank you :D
Sorry for providing you with the wrong information @jayper, while researching before buying this player a few weeks ago I read lots of posts, I think I was thinking back to @RESET_9999 post's about having to convert DTS-HD to LPCM for muxing in mp4. :oops: Hopefully you are able to resolve the problem by changing a setting like I was.
jayper
Post by jayper » Tue Dec 08, 2020 3:40 pm
Thank you both for the guidance. I'll take a look!
magnetoeric
Post by magnetoeric » Tue Dec 08, 2020 5:27 pm
RayDawGGG wrote:
Mon Dec 07, 2020 6:13 pm
magnetoeric wrote:
Sun Dec 06, 2020 6:45 pm
Thank you. The menu is different on CX and it doesn't even show the hdr details like it did in your pic (dolby vision profile under general section). Is it because I've connected my shield to my onkyo receiver instead of directly to my tv? I've watched many dolby vision mkv remuxes and I too feel like the picture doesn't look bright at all. HDR looks great though.
You have to highlight the word HDMI MODE.. https://i.imgur.com/nlTBDa3.jpg then select it.. it will change https://i.imgur.com/L9EdX60.jpg
Thank you :)
Doosethemoose
Post by Doosethemoose » Tue Dec 08, 2020 7:01 pm
Sorry if this question has been answered but I just found this thread and have not read all 250+ pages.
I have a Sony X900f which supports Dolby Vision, but apparently that's only profile 5 and not 7 like most UHD discs. Is there a lossless way to get my TV to properly display DV profile 7 content?
lexyz
Post by lexyz » Tue Dec 08, 2020 8:26 pm
Sony X900f
Sadly not possible. XF90 plays properly only DoVi p5
XH90 is the only Sony TV plays DoVi 5, 7 MEL and 8
Doosethemoose
Post by Doosethemoose » Tue Dec 08, 2020 8:38 pm
Boo. And there's no way to just lug my PC over and connect it directly and have it work either since there's no DoVi players for Windows that I know of
Roberespa
Post by Roberespa » Tue Dec 08, 2020 11:31 pm
I have tried to create the Lord of the Rings with all the possible forms that are offered to me in the forum, the only one that worked was mp4.
With it I have Dolby Vision.
Just one more thing (if you are so kind to answer me):
Hevc1 and hevc2 can be merged directly from the system symbol to .mkv
If so, please send me the command. I'm desperate.
Thank you very much in advance.
Sincerely:
-Rober.
DaMacFunkin
Post by DaMacFunkin » Wed Dec 09, 2020 6:07 am
Sincerely:
-Rober.
Hi, you don’t say what your playback device is?
TLOTR and The Hobbit are MEL so the easiest way to create Dolby Vision MKV is Makemkv.
Roberespa
Post by Roberespa » Wed Dec 09, 2020 11:38 am
Interestingly when I use:
MUX_AND_CONVERT_TO_MEL
or
MUX_AND_CONVERT_TO_PROFILE_81
and with tsMuxeR I convert it to .ts or .m2ts in Mediainfo no trace of Dolby Vision. And the TV opens it as HDR but not a trace of Dolby Vision.
General
Nombre completo : T:\El Señor de los Anillos La Comunidad del Anillo V.E 2001 UHD-REMUX Dolby Vision HDR10\El Señor de los Anillos La Comunidad del Anillo V.E 2001 UHD-REMUX Dolby Vision HDR10.ts
Formato : MPEG-TS
Tamaño de archivo : 57,8 GiB
Duración : 1 h 45 min
Modo de tasa de bits : Variable
Tasa de bits general : 78,3 Mb/s
Tasa de bits genral máxima : 35,5 Mb/s
Vídeo
ID menú : 1 (0x1)
Formato : HEVC
Formato/Info : High Efficiency Video Coding
Formato del perfil : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
ID códec : 6
Ancho : 3 840 píxeles
Alto : 2 160 píxeles
Relación de aspecto : 16:9
Velocidad de fotogramas : 23,976 (24000/1001) FPS
Espacio de color : YUV
Submuestreo croma : 4:2:0 (Type 2)
Profundidad bits : 10 bits
Rango de color : Limited
Colores primarios : BT.2020
Características transferencia : PQ
Coeficientes matriz : BT.2020 non-constant
Principios color monitor masterización : Display P3
Luminancia monitor masterización : min: 0.0050 cd/m2, max: 4000 cd/m2
Nivel ligero contenido máximo : 602 cd/m2
Nivel ligero fotograma medio máximo : 184 cd/m2
Roberespa
Post by Roberespa » Wed Dec 09, 2020 11:46 am
Sincerely:
-Rober.
Inside the LG menu.
The television model says:
OLED55B6V-Z
and at the end an interesting fact.
Dolby Vision 0.9.0
I also tried MakeMKV v1.15.3 but the TV won't open it.
Demomento only worked (opened it) with Dolby Vision in .mp4
Thanks for answering me.
I wait your answer.
I don't know if the problem will be the file size ... = (
Post by RESET_9999 » Wed Dec 09, 2020 12:05 pm
Inside the LG menu.
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
you don't need a ts/mkv file if you play them in your LG B6. stick with the mp4muxer.
LOTR are [s] FEL DV [/s]
userr
Post by userr » Wed Dec 09, 2020 2:00 pm
Sony X900f
what do you mean "only sony tv", if an external device plays profile7 mkv the tv displays what the external device sends
lexyz
Post by lexyz » Wed Dec 09, 2020 2:58 pm
I mean dolby vision playback by internal TV Media player or Plex without external device
DaMacFunkin
Post by DaMacFunkin » Wed Dec 09, 2020 3:05 pm
Sincerely:
-Rober.
Inside the LG menu.
OLED55B6V-Z
Dolby Vision 0.9.0
I wait your answer.
Your tv will not play DV from mkv.
