Spider-Man Far From Home
floatinjoe
Post by floatinjoe » Sun Dec 06, 2020 10:35 pm
I have never seen this before, so I wanted to check here. There are two titles that could be the correct one, but I'm not sure which it is. The only differences are the chapters and also that one has a source file of an .mpls and the other is a .m2ts
Thoughts?
Title information
Name: Spider-Man: Far From Home (English)
Source file name: 00001.mpls
Duration: 2:09:23
Chapters count: 16
Segment count: 1
Segment map: 1
File name: Spider-Man- Far From Home_t00.mkv
Title information
Source file name: 00001.m2ts
Duration: 2:09:23
Segment count: 1
Segment map: 1
File name: Spider-Man- Far From Home_t17.mkv
Re: Spider-Man Far From Home
Post by dcoke22 » Sun Dec 06, 2020 11:04 pm
The one that is a mpls and has chapters is probably the one you want.
Post by MartyMcNuts » Mon Dec 07, 2020 12:01 am
floatinjoe wrote: Sun Dec 06, 2020 10:35 pm I have never seen this before, so I wanted to check here. There are two titles that could be the correct one, but I'm not sure which it is. The only differences are the chapters and also that one has a source file of an .mpls and the other is a .m2ts
Thoughts?
Title information
Duration: 2:09:23
Chapters count: 16
Segment count: 1
Segment map: 1
Title information
Duration: 2:09:23
Segment count: 1
Segment map: 1
You should be looking at the playlists (mpls). No need to look at the m2ts files. Just out of curiosity, when looking at the playlist in mediainfo, at the end of the video section, does it refer to 00001.m2ts?
floatinjoe
Post by floatinjoe » Tue Dec 08, 2020 4:35 pm
I figured it was the .mpls title. I will need to download mediainfo and install it on my mac to see what it says.
Ezatoka
Post by Ezatoka » Tue Dec 08, 2020 8:47 pm
As much as I observed, the "Segment map" on a MPLS file refers to the m2ts files in the streams folder.
floatinjoe
Post by floatinjoe » Tue Dec 08, 2020 9:58 pm
Ezatoka wrote: Tue Dec 08, 2020 8:47 pm As much as I observed, the "Segment map" on a MPLS file refers to the m2ts files in the streams folder.
That's interesting. I wonder if the chapters are only in the MPLS files.
