Westworld S3 Episode 2+3
Barod
#1 Post by Barod » Mon Dec 07, 2020 8:07 pm
I've got problems with ripping episodes 2+3 on the first UHD. Here the displayed Errors.
DEBUG: Code 0 at lW8!Lj=.|@*'mV5Pf:29398691
Fehler 'SCSI-Fehler - ILLEGAL REQUEST:INVALID FIELD IN CDB' trat auf während des Auslesens von '/BDMV/STREAM/00030.m2ts' bei Offset '0'
DEBUG: Code 101000192 at ui]{;3u:7O4yrt7iLp:29395149
DEBUG: Code 0 at UW?dhjj"*.cx+(2I6;o9:213133687
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:121262348
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:121262210
DEBUG: Code 0 at i/KyO`_OY#FKb6Mwy:rI:121261773
DEBUG: Code 0 at 1XR@MIO+; 4B9/nG-DH[:213136769
DEBUG: Code 0 at OWrjJITP_D@d<!P;:121262394
DEBUG: Code 0 at Tk_-[@5B#==Kelrv;&y41:29400485
DEBUG: Code 0 at OWrjJITP_D@d<!P;:121262509
DEBUG: Code 0 at tni3#1y0}DE~O/Pvgm:121269731
DEBUG: Code 0 at tni3#1y0}DE~O/Pvgm:29401819
This is the second set of UHD's. The first set had a damaged UHD1 so I got a replacement but there is the same problem.
The other UHD where ripped without any failures.
Can someone give me a tip what to do.
Barod
Re: Westworld S3 Episode 2+3
#2 Post by shawnc22 » Mon Dec 07, 2020 9:09 pm
Barod
#3 Post by Barod » Tue Dec 08, 2020 11:45 am
Thanks for this link, but there is nothing written about the error:
Is the only other solution to get an other drive?
#4 Post by dcoke22 » Tue Dec 08, 2020 4:00 pm
Did you try cleaning the discs? Even brand new discs sometimes have an oily film on them that is almost invisible to the eye but not the laser.
Esch30
#5 Post by Esch30 » Tue Dec 08, 2020 10:53 pm
Has anyone had issues with Disc 3 in this set?
I was able to successfully do full disc backups of Discs 1 and 2, but Disc 3 is unable to decrypt. I sent the dump already, but I've never had one disc out of a series of discs within a season fail to decrypt when the others decrypted without issue.
preserve
#6 Post by preserve » Wed Dec 09, 2020 8:27 am
If the studio makes multiple versions of each disc in the set with different keys, then it’s possible you could have some discs in the set that work and others that don’t, based on the random combination of the dumps already submitted. Just a guess.
You’re on the right path though, now that you’ve submitted the dump, your disc should be supported soon.
Using: ASUS BW-16D1HT 3.00
Esch30
#7 Post by Esch30 » Wed Dec 09, 2020 10:48 pm
I appreciate the explanation. I tried again and it's working now! :mrgreen:
Barod
#8 Post by Barod » Fri Dec 18, 2020 8:34 am
After recieving the 3rd set of discs, all worked fine.
GoodBoy
#9 Post by GoodBoy » Fri Jan 12, 2024 6:09 pm
Westworld S3 4k set.
Having an Issue with the 4k Disc 2 in this set. Disc 1 ripped without issue, disc 3 is ripping now. Disc 2 just said "No Disc".
I have 2 LG drives, one flashed to whns60 1.02 patched, the other flashed to whns40 1.05 patched(both are whns40 drives).
Both drives exhibited the same behavior, No Disc. This is a brand new set I just opened. I put disc 2 in my Panasonic 4k player, works fine.
Do I need to put makemkv in logging mode or something? It doesn't generate a log when it does this. I'm running v1.17.5
GoodBoy
#10 Post by GoodBoy » Fri Jan 12, 2024 10:40 pm
Weird. After disc 3 completed, I retried disc 2 and it worked.
