Hello everyone,
I purchased this drive a few days ago and it is not reading any dics in Windows 10 or MakeMKV even with the pre-loaded original firmware 3.10.
I have been troubleshooting this issue and made the following changes so far.
# Before any modification #
- Initially came with an unpatched 3.10 firmware
- Drive appears in Windows but does not read ANY disc (BD, DVD, et.)
- No disc message in MakeMKV
# Update to 3.10 MK #
- Flashed 3.10 MK with ASUS tool https://www.makemkv.com/forum/viewtopic ... 16&t=18933
# Downgrade to 3.02 DE #
- Flashed 3.02 DE with ASUS tool https://www.makemkv.com/forum/viewtopic ... 16&t=18933
# Update to 3.03 MK #
- Flashed 3.03 MK with ASUS tool https://www.makemkv.com/forum/viewtopic ... 16&t=18933
I have downgraded again to 3.02 just in case the drive came DOA and I need to return it. Also, this is the current info displayed in MakeMKV:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Firmware version: 3.02
# Further details #
- The drive was manufactured in 29th February 2020
- Connected to the PC with the adapter Unitek Y-1039
- I tried to connect the drive with a SATA cable and to the power supply but the issue persisted
- I have also tried MakeMKV 1.15.1 and 1.15.3 but no luck so far.
Any help would be really appreciated.
Thanks a lot!
New Asus BW-16D1HT not reading ANY discs even in Windows 10
crashnight
PrimoAngelo
doryphore
Re: New Asus BW-16D1HT not reading ANY discs even in Windows 10
I think I have the same problem even though it was working fine for 1 year, probably a windows update ?
Below is the makemkv info :
Informations lecteur
Nom du lecteur SE : H:
Fabricant : ASUS
Produit : BW-16D1HT
Révision : 3.10
Numéro de série : KLLJ4HD2834
Date micrologiciel : 2119-01-04 10:14
Marqueurs d'encryptage bus : 1F
Version AACS la plus haute : 72
Firmware version: 3.10
Fabricant : ASUS
Produit : BW-16D1HT
Révision : 3.10
viewtopic.php?f=1&t=23931doryphore wrote: Sat Dec 12, 2020 9:32 am I think I have the same problem even though it was working fine for 1 year, probably a windows update ?
Someone else reported problems with a recent Windows feature update.
