Invalid MIT-MAGIC-COOKIE-1 keymakemkv: cannot connect to X s
renareto
Post by renareto »
I'm trying to use MakeMKV on my Debian distro.
- I've installed dependances
- compiled all
but, when I run it from /usr/bin (./makemkv) I received the error on the subject.
Where I do mistake?
TIA
Renato
skittle
Re: Invalid MIT-MAGIC-COOKIE-1 keymakemkv: cannot connect to
Post by skittle »
What version of debian? All packages up to date? Post console log...
You cant just say "it doesnt work" and expect us to figure out whats wrong!
btw /usr/bin/ should be included in your $PATH, so you can just call makemkv from anywhere.
renareto
Post by renareto »
think to have solved,
I ran the command with the standard user, not root. and it works.
TIA!
Renato
