Post by shawnc22 »
Still RGB 8bit here on my B9. Latest 5.0 firmware on the TV and 8.2.1 on the Shield experience. Tested with both UHD disk backup DV and Netflix DV.
Post by Manixx2020beyound »
Sony /cx
X700rgb-8
X700rgb-8
Has to be CX/shield hdmi hand shake
On the CX shield behaves like the new Xbox that’s weird makes it own adjustments & CX sees it as a gaming machine, deep colors prompt u to turn off ect
This never happened to me before CX is only 3 weeks old taking the CX out off the equation & directly connected the shield is still not gaving me rgb8 dv from the shield
Even on my other doblyvision TVs.
Lol maybe my shield is broken lol
LLDV on shield is still good.
I’ll wait for other CX/shield owners to respond.
Still getting RGB DV on both my Vizio TV and OLED C8... latest Shield firmware.
Since you're getting RGB from the x700, it sounds like the Shield has an issue with the CX. I would blame the Shield though, what a terrible device for DV, so many issues...
DaMacFunkin
Post by DaMacFunkin »
Like I said, the guy who tested my C9 edid said the LG was requesting LLDV from the Zidoo / Shield, don't know why it is different on the B9, the B9 and C9 don't have the same processor so might have different firmware.
Attach-edid0003.zip
(353 Bytes) Downloaded 885 times
Anybody want a try?
This is what it displays now of course I have to edit setting on the vertex to<br />To copy shield edid tx0
Got it to work very strange behavior indeed
I think it was my vertex2 it replaces the edid so a lot of times when switching back & forth between settings edid gets locked 🔒 in, powering down everything un plug still works lol.
Only difference this time my other 3 screens are gettingshield CX rgb8 doblyvision perfect shield second screen tlc black screen like the CX was getting 3rd
Screen vizo what the CX was getting before
12bit 709
But all this started happening recently well today ,it’s probably 2.1 hdmi in the loop
Last edited by Manixx2020beyound on Fri Dec 04, 2020 11:12 pm, edited 3 times in total.
DaMacFunkin
Manixx2020beyound wrote:
Fri Dec 04, 2020 10:52 pm
Hi, how did you get it to work, attached my edid on a previous post.
Post by shawnc22 »
DaMacFunkin wrote:
Fri Dec 04, 2020 10:43 pm
Like I said, the guy who tested my C9 edid said the LG was requesting LLDV from the Zidoo / Shield, don't know why it is different on the B9, the B9 and C9 don't have the same processor so might have different firmware.Attach-edid0003.zip
Anybody want a try?
There's an easy way to just test this on your own. Play some DV content on your Shield, and then open up the HDMI diagnostics menu on your C9 and check what kind of signal it's receiving. No need to worry about what anyone else's HDFury is reporting when you can get it directly from your TV.
zxaura1
Post by zxaura1 »
Hello guys,
I only have a LG OLED E6 (2016) which plays some (not all) DV mp4 and TS files, but not any mkv files as Dolby Vision. I wonder if any of you knows a proper way to convert mkvs created with the latest MakeMKV, to DV .ts files (latest TSMuxer doesn't work for me, it creates a ts file that plays in HDR).
Maybe you @yusesope ?
Thanks in advance
pete19
Post by pete19 »
I have a LG CX and Oppo 203 and want to know if the DV signal displayed by the LG CX is tv-led or player-led.
How can I get that info ?
Thx.
DaMacFunkin
pete19 wrote:
Sat Dec 05, 2020 5:42 am
Thx.
The Oppo can be set to player led or tv led for Dolby vision in the hdr settings.
pete19
Post by pete19 »
DaMacFunkin wrote:
Sat Dec 05, 2020 6:55 am
yes, I know that. But I want to leave on AUTO and see what DV type (tv-led or player-led) it sends depending on the media it plays back
is there any way to get that info ?
TickTock
Post by TickTock »
PlatypusW wrote:
Tue Dec 01, 2020 11:59 am
I believe the furtherest we have got with the seeking issue, is that it is somehow related to the length of the file.
Interestingly, different formats, whilst they don’t support DV, supposedly allow seeking to work with long duration.
I haven’t got my player yet to investigate myself, but I think that’s all we know at the moment. Duration seems to be a factor but not necessarily the only factor at play.
Can’t help with the subtitle sync issue though, maybe someone else can.
Thanks for your response and for the information. I'm going to try an experiment with some files in the hope I can help narrow down/confirm the cause.
RESET_9999 wrote:
Thu Dec 03, 2020 11:35 pm
I'm not sure of that anymore ...
The Lord of the rings trilogy all failed to FF/RW.
same for the first 2 Hobbit.
but somehow the Hobbit 3 has no issue with FF/RW even though it's a 2h40 movie. I'm sure I had issues with title shorter than that.
Last night I watched The Lord of the Rings The Fellowship of the Ring and I was able to fast forward. I used the latest version of tsMuxer and muxed both parts to individual m2ts files.
TickTock wrote:
Sat Dec 05, 2020 1:18 pm
I merged mine in a single TS file.
So if FF works for each individual part, that pretty much confirms the issue is related to the length of the movie.
thank you
magnetoeric
Post by magnetoeric »
shawnc22 wrote:
Fri Dec 04, 2020 9:21 pm
Could you tell me how to access this menu on my CX?
RayDawGGG
Post by RayDawGGG »
shawnc22 wrote:
Thu Dec 03, 2020 10:22 pm
DaMacFunkin wrote:
Thu Dec 03, 2020 10:01 pm
ive been thinking this over and it makes sense...
Your CX is internally processing HDR via its app correctly, correct colours, correct tone map and as such it looks good.
Dolby Vision from the shield is being processed by the shield (player led LLDV) and as such looks a little darker, you also have the incorrect color to deal with.
For some reason the LG’s even though they can do TV led processing of Dolby Vision, request player led by default.
If you have an Oppo or Oppo clone you can force TV led processing (RGB 8 bit tunnelling) and it looks brighter than selecting player led ( 12 bit LLDV).
Not sure where you're getting this from, but LG's do not force the Shield to default to LLDV. At least on my B9, RGB tunneling is the default DV mode. Unless this changed in the new X-generation of TV's, you can only get LLDV from the Shield into an LG Oled via HDFury EDID spoofing.
I appreciate the feedback and knowledge. So the Shield still has color issues.. and the LG CX does a great job with HDR. I am now going to invest in a 4K UHD player(to support the 4K disc market). While I enjoy having the ability to play backups and save shelf space, I want to get the best picture on my CX. As the technology improves, maybe one day the Shield will be a great alternative. I'm going to remux to m2ts to see if DV logo shows in the CX plex app & check for visual differences.
