Mulan 4K USA rip isn't working. The playback is dithered and jumbled.
I'm running MakeMKV v1.15.3 win (x64-release).
Any ideas on how to correct this? Thank you
Mulan 4K USA - Rip Not Working
Re: Mulan 4K USA - Rip Not Working
What player are you using?
JulesKeeper
Nvidia Shield TV Pro. My other 4K UHD movies are playing fine.
Does the file work correctly in a different player? For instance, in VLC (https://www.videolan.org/vlc/) or MPV (https://mpv.io) on your computer?
Did you post process the file in some way?
JulesKeeper
UPDATE:
Yes, Mulan 4K USA works on a different player. I'm in the process of resetting my Nvidia Shield TV Pro.
Thank you for the responses.
