Mulan 4K USA - Rip Not Working
JulesKeeper
Post by JulesKeeper » Fri Dec 04, 2020 7:15 pm
Mulan 4K USA rip isn't working. The playback is dithered and jumbled.
I'm running MakeMKV v1.15.3 win (x64-release).
Any ideas on how to correct this? Thank you
Re: Mulan 4K USA - Rip Not Working
Post by dcoke22 » Fri Dec 04, 2020 7:17 pm
What player are you using?
JulesKeeper
Post by JulesKeeper » Fri Dec 04, 2020 8:03 pm
Nvidia Shield TV Pro. My other 4K UHD movies are playing fine.
Post by dcoke22 » Fri Dec 04, 2020 9:56 pm
Does the file work correctly in a different player? For instance, in VLC (https://www.videolan.org/vlc/) or MPV (https://mpv.io) on your computer?
Did you post process the file in some way?
JulesKeeper
Post by JulesKeeper » Sun Dec 06, 2020 4:41 pm
UPDATE:
Yes, Mulan 4K USA works on a different player. I'm in the process of resetting my Nvidia Shield TV Pro.
Thank you for the responses.
