Is this real DV?
Gallo73
Is this real DV?
Post by Gallo73 » Fri Dec 04, 2020 12:43 pm
I have been thinking of redoing my MKVs now we have DV support into TS format and playing with the modified exoplayer. Before I embarked on the task I did a test with an older MKV I had and remuxed it to M2TS (apparently less processing for the player) and tried it on my setup which is:
Sony XH95 TV
Sony X800M2 Player via USB
This seems to trigger DV, but given Sony's less than perfect DV implementation I wanted confirmation that the DV meta data was being used. I also did the same with a non DV file and this appears not to have a DV track going into the player (even though everything is output in a DV format on this player once DV is turned on). I lose Atmos as it's discarded by TSMuxer when I load the file but I get DTSHD (I don't have Atmos speakers so it's no big deal).
The Media info before and after for both these files are below and I've attached a screenshot of what the player shows as the input and output files. Can anyone confirm this is real Dolby Vision from this information?
As a side note I couldn't get this to work with the nightly TsMuxer (although that was with Midsommar) - So I used the 04.06 fix version.
Last Jedi DV.jpg (58.31 KiB) Viewed 8917 times
Star Trek HDR 10.jpg (48.7 KiB) Viewed 8917 times
THE LAST JEDI BEFORE REMUX
General
Complete name : E:\Star Wars Episode VIII The Last Jedi (2017) (2160p REMUX DV).mkv
Video #1
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Video #2
Format : HEVC
Audio #1
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Audio #2
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
THE LAST JEDI AFTER REMUX
General
Complete name : F:\Star Wars Episode VIII The Last Jedi (2017) (2160p REMUX DV).m2ts
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Audio #1
Menu ID : 1 (0x1)
Format : DTS XLL
Compression mode : Lossless
STAR TREK 2009 BEFORE REMUX
General
Complete name : U:\Star Trek (2009) (2160p REMUX)\Star Trek (2009) (2160p REMUX).mkv
Video
Format : HEVC
Audio #1
Audio #2
Format : DTS XLL
Star Trek 2009 AFTER REMUX
General
Complete name : F:\Star Trek (2009) (2160p REMUX).m2ts
Video
Menu ID : 1 (0x1)
Format : HEVC
Audio #1
Menu ID : 1 (0x1)
Format : DTS XLL
