Re: SDFtool Flasher
#121 Post by SamuriHL » Thu Dec 03, 2020 9:06 pm
morbius wrote:
Thu Dec 03, 2020 8:56 pm
Doesn't really matter. 1.02 is probably preferable in that situation.
EDIT: Just saw your newest post. Use 1.00. That's the best firmware.
thanks, will run that on my 16D1HT for a while and see how it goes. I also have an Asus BC-12D2HT on 3.11MK, would that also benefit from being cross-flashed to WH16NS60?
Not really familiar with that drive. It might but others may know more than I on that one.
Re: SDFtool Flasher
#122 Post by MartyMcNuts » Fri Dec 04, 2020 5:44 am
No, please leave your BC-12D2HT on 3.11-MK. I've had countless number of people having issues after cross-flashing this particular drive. Please leave it alone.
Re: SDFtool Flasher
#123 Post by SamuriHL » Fri Dec 04, 2020 12:51 pm
Good to know. That's not a drive I've had any experience with so always nice to know what to tell people.
morbius
Re: SDFtool Flasher
#124 Post by morbius » Fri Dec 04, 2020 5:19 pm
thanks @MartyMcNuts. My 12D2HT is rarely used so will leave it on 3.11MK.
My 16D1HT has been very solid on 3.10MK. My only gripe would be that sometimes when opening UHD discs it can make some alarming seek noises that sound as if the drive is about to die, but it's a bit random and the drive then opens the disc. I'm curious to see if the WH16NS60 firmware helps with that.
But I also now have the BU40N in a Vantec enclosure, and although I've not used it much as yet I would say that while it might be small, it's pretty mighty.
Re: SDFtool Flasher
#125 Post by MartyMcNuts » Fri Dec 04, 2020 11:30 pm
Yep, the BU40N rocks!!
StarForce
Re: SDFtool Flasher
#126 Post by StarForce » Sat Dec 05, 2020 6:16 pm
MartyMcNuts wrote:
Thu Dec 03, 2020 8:37 pm
StarForce wrote:
Thu Dec 03, 2020 4:55 pm
Hi, guys!
I bought an ASUS BW-16D1HT E-Green (BULK + S/W) (I can't register it, ASUS.com didn't recognize serial). https://i.imgur.com/MUB5ljk.png
Once installed it prompted a message about updating firmware and I thought it was best idead to do it (I don't remember what versión it was) but now it's v3.10 after updating.
Is there any differences beetwen Green version and other versions?
The procedure is to put "sdftool_flasher.exe" and "DE_ASUS_BW-16D1HT_1.01.bin" in the same folder, double click on "sdftool_flasher.exe" and... https://i.imgur.com/TVBEi9q.png
Do I choose "WRITE Firmware", "READ Firmware", "RECOVER Drive" or "Please select a firmwate to write?
Thanks a lot for your help and efforts.
NO!!!!!!
The attached ASUS 1.01 firmware is only for recovery of an old drive. Do not use it on your drive.
You can download the MK firmware pack on the forum. Put the SDFtool Flasher in the folder with the MK firmware pack and flash drive with ASUS 3.10 from the MK firmware pack.
Didn't do it cause I wasn't sure. I don't understand english very well and that is a particularly serious theme.
I downloaded the file (Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack (20.07.2020).zip
Inside, there is a file called "ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin" in this directory "mk-firmware-pack-20200720 / MK / ASUS / BW-16D1HT"
Is the file that I have to put in the same folder than the SDFtool Flasher?
Thanks a lot for your help. Really appreciate it!
Re: SDFtool Flasher
#127 Post by MartyMcNuts » Sat Dec 05, 2020 10:38 pm
Hi, guys!
NO!!!!!!
Yes, that is the latest firmware file for your drive. It would be helpful to know how old your drive is and what firmware was on it before you updated it.
StarForce
Re: SDFtool Flasher
#128 Post by StarForce » Sun Dec 06, 2020 1:24 am
I bought it on November 27 but I didn't remember what firmware version it had. Just the updating message and then I accepted. That numb I am.
Re: SDFtool Flasher
#129 Post by MartyMcNuts » Sun Dec 06, 2020 2:02 am
OK..
Flashing instructions are in the first post of this thread.
36inarow
Re: SDFtool Flasher
#130 Post by 36inarow » Sat Dec 12, 2020 5:26 pm
Just like to say a big thank you to Mr McNuts
I was expecting this to be a long and frustrating process - instead 10mins to find this tread then piece of pi$$.
For the newbies like me - ASUS BW-16D1HT with FW 3.10 arrived today along with an external 5.25 caddy from Lindy.
Put it all together - download the SDFtool Flasher and am ripping less then 5mins later.
Again, thank you.
Re: SDFtool Flasher
#131 Post by MartyMcNuts » Sat Dec 12, 2020 9:44 pm
Again, thank you.
You're welcome!! Enjoy!!
Marzellius
Re: SDFtool Flasher
#132 Post by Marzellius » Sun Dec 13, 2020 8:11 am
MartyMcNuts wrote:
Tue Nov 10, 2020 3:47 am
ratman7788 wrote:
Mon Nov 09, 2020 11:16 pm
i am so lost i keep getting a error i want to use this drive to back up uhd disc
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIKYV56JL5051
Firmware date: 2120-05-07 09:35
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Easy peasy!!
1. Flash BP60NB10 1.02 from the MK firmware pack (with the "enc" option checked as 1.02 is an encrypted firmware).
2. Once that flash has completed, flash BP60NB10 1.00 from the "old" folder in the MK firmware pack.
Done! Start ripping UHD discs!!
I have this same drive, can you clarify for me why we have to flash first with the 1.02 firmware? Isn't that the current version? I'm just not clear why you cant just flash to 1.00.
Re: SDFtool Flasher
#133 Post by Billycar11 » Sun Dec 13, 2020 9:08 pm
Because of downgrade checks
Weez1000
Re: SDFtool Flasher
#134 Post by Weez1000 » Mon Dec 14, 2020 8:03 pm
Thank you guys for the hard work you put into this. I got my Asus 16D1HT drive today. It came with 3.10 on it and i flashed the MK 3.10 firmware and it was working in less than 5 minutes. The guides and firmware is most helpful.
Re: SDFtool Flasher
#135 Post by MartyMcNuts » Mon Dec 14, 2020 10:30 pm
You're welcome! Enjoy 😊
