I am curious how active Mike is with working on this though, as I've submitted the required files before, including submitting one that MakeMKV identifies incorrectly, but those discs haven't been resolved.
Midway
Re: Midway
Using: ASUS BW-16D1HT 3.00
Re: Midway
Quite the valid question... Maybe he's devoting too much time toward that UHD stuff?
Re: Midway
This thread alone has user submissions, which should help some way.
Is there a digital signature users could send, along with what they have uncovered as the correct playlist?
I know the program tries to guess the right playlist based on java code, would analyzing and fixing the issue on a more recent movie fix the analysis heuristics to work on pretty much everything current and older?
We could take a Blu-ray player with 5 year old firmware and it analyzes and plays correctly, so I get that the software emulation is still not quite perfect.
Re: Midway
Just finished checking the Blu-ray that came with the 4K version and this is the correct play list for the Blu-ray that was included with the 4K disc.
UPC code for the 4K cover art: UPC 31398 31416
Title information
Source file name: 00539.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 504,510,501,507,502,505,506,509,503,508
File name: Midway_t119.mkv
UPDATE: Have sent to support, an image of the Midway disc so that they can figure out the Java scripting issue with this Blu-ray Disc that comes with the 4K UHD disc.
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
2 x 3.46 GHz 6-Core Intel Xeon (mid 2012)
64GB Memory
Mac OS X 10.14.6
64GB Memory
Mac OS X 10.14.6
TwitchBronBron
Re: Midway
Blu-Ray + Dvd + Digital from Target online (UPC 0 3139831413 4 80).
Using DVDFab Passkey and VLC, looks like it's reading 00539.
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
12:11:50.3253416 PM vlc.exe 10312 FileSystemControl E:\BDMV\PLAYLIST\00539.mpls INVALID DEVICE REQUEST Control: 0x90390 (Device:0x9 Function:228 Method: 0)
12:11:50.3253565 PM vlc.exe 10312 QueryAttributeInformationVolume E:\BDMV\PLAYLIST\00539.mpls SUCCESS FileSystemAttributes: Case Preserved, Case Sensitive, Unicode, Named Streams, Read Only, 0x1400200, MaximumComponentNameLength: 254, FileSystemName: UDF
12:11:50.3262666 PM MsMpEng.exe 4352 CreateFileMapping E:\BDMV\PLAYLIST\00539.mpls FILE LOCKED WITH ONLY READERS SyncType: SyncTypeCreateSection, PageProtection: PAGE_EXECUTE|PAGE_NOCACHE
12:11:50.3262823 PM MsMpEng.exe 4352 QueryStandardInformationFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:50.3263434 PM MsMpEng.exe 4352 ReadFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS Offset: 0, Length: 2,302, I/O Flags: Non-cached, Paging I/O, Synchronous Paging I/O, Priority: Normal
12:11:50.7392307 PM vlc.exe 10312 QueryStandardInformationFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:50.7392629 PM vlc.exe 10312 ReadFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS Offset: 0, Length: 2,302, Priority: Normal
12:11:50.7393344 PM vlc.exe 10312 ReadFile E:\BDMV\PLAYLIST\00539.mpls END OF FILE Offset: 2,302, Length: 28,672, Priority: Normal
12:11:50.7394032 PM vlc.exe 10312 ReadFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS Offset: 2,298, Length: 4, Priority: Normal
12:11:50.7394359 PM vlc.exe 10312 ReadFile E:\BDMV\PLAYLIST\00539.mpls END OF FILE Offset: 2,302, Length: 28,672, Priority: Normal
12:11:50.7394577 PM vlc.exe 10312 CloseFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS
12:11:51.5858357 PM vlc.exe 10312 CreateFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS Desired Access: Generic Read, Disposition: Open, Options: Synchronous IO Non-Alert, Non-Directory File, Attributes: N, ShareMode: Read, Write, AllocationSize: n/a, OpenResult: Opened
12:11:51.5872354 PM vlc.exe 10312 QueryStandardInformationFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS AllocationSize: 4,096, EndOfFile: 2,302, NumberOfLinks: 1, DeletePending: False, Directory: False
12:11:51.5872736 PM vlc.exe 10312 ReadFile E:\BDMV\PLAYLIST\00539.mpls SUCCESS Offset: 0, Length: 2,302, Priority: Normal
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
andrewskaterrr
Re: Midway
I know I'm late to the party but I wanted to post my findings as a quick go-to for people because there's a lot of different versions. I compared each chapter in both rips to the Bluray's chapters using my PS3.
Retail 4K + Bluray + Digital
UPC: 0 3139831416 5
4K Disc:
Source file name: 00504.mpls
Segment count: 1
Segment map: (502,501,503,500,506,507,505)
File name: Midway_t91.mkv
Bluray Disc:
Segment count: 10
File name: Midway_t122.mkv
UPC: 0 3139831416 5
4K Disc:
Segment count: 1
Bluray Disc:
Segment count: 10
Re: Midway
Have you re-scanned the disc with 1.16.4? There's enhancements that were made around identifying the correct title amongst multiple playlists.
Re: Midway
For what it's worth, I upgraded to 1.16.4 and it didn't detect the primary playlist at all. In fact, that has never worked for me, it never even suggests one. I have java registered but it seems like it's not even trying.
Re: Midway
I'm running 1.16.4 and cannot rip this BD disc. The second title on the list seems to be the one others have used:
Title information
Name: Midway (English)
Comment: FPL_MainFeature
Duration: 2:18:24
Chapters count: 16
Segment count: 10
File name: Midway-FPL_MainFeature_t04.mkv
I end up with Read Error and HashCheck Errors. This disc is clean and looks good. I've used this drive for tons of other blu-rays. Do I need to patch the firmware?
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLAK6HF3247
Highest AACS version: 70
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Revision: 1.05
Re: Midway
I am running 1.16.4 and cannot rip a Midway BD (library copy). I found the playlists listed above but I get a sea of hash errors. The disc is very clean and my drive is good (I've used it for many other BDs). Any idea where to start?
centuryx476
Re: Midway
Hello All,
So just to be sure. Since there is multiple postings here
The .mpls is the below for the 4K disc?
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
MKVPlexRoku
Re: Midway
Thanks for this! Since I didn't find the other one everyone else was mentioning, your post was the one that led me to the right one.andrewskaterrr wrote: ↑Fri Jul 09, 2021 12:33 amI know I'm late to the party but I wanted to post my findings as a quick go-to for people because there's a lot of different versions. I compared each chapter in both rips to the Bluray's chapters using my PS3.
UPC: 0 3139831416 5
4K Disc:
Segment count: 1
Re: Midway
FYI....( java did not work for me on this disk)
however I am able to confirm
MIDWAY 2019 netflix blu ray version correct playlist as:
Title information
Source file name: 00741.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 507,501,509,502,504,510,508,506,503,505
File name: Midway_t158.mkv
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
LordMustangGT
Re: Midway
This work with for my Bluray 1080p version, that came in my 4K case, as well. It was 00539, and all the segments were in the right order, but the file name was a different number, but it still was the right one. UPC was the same as well too. Also the 4K bluray version in this thread with the link to it, work aswell for the 4k version.kfreeb wrote: ↑Tue Dec 01, 2020 6:10 pmJust finished checking the Blu-ray that came with the 4K version and this is the correct play list for the Blu-ray that was included with the 4K disc.
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Asus x299 Rampage VI Extreme
Intel 7920x
32gb GSkill
Gigabyte Waterforce 3080Ti WB ver.
Asus 4k Bruray drive
Intel 7920x
32gb GSkill
Re: Midway
Even after finding the right title/playlist, did you still get the "FFMPEG_ERROR: FFDEC000: [truehd @ 0x7fb9b9d82380] No restart header present in substream" error messages?LordMustangGT wrote: ↑Thu Dec 29, 2022 8:13 pmThis work with for my Bluray 1080p version, that came in my 4K case, as well. It was 00539, and all the segments were in the right order, but the file name was a different number, but it still was the right one. UPC was the same as well too. Also the 4K bluray version in this thread with the link to it, work aswell for the 4k version.kfreeb wrote: ↑Tue Dec 01, 2020 6:10 pmJust finished checking the Blu-ray that came with the 4K version and this is the correct play list for the Blu-ray that was included with the 4K disc.
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
