I've recently been trying to rip (full disc) the UHD of Black Hawk Down (UK release) and finally made a copy but this is what the program log showed:
File "dummy_f.dat" was skipped
Encountered 1 errors of type 'Read Error' - see http://makemkv.com/errors/read/
Backup done.
Unfortunately I wasn't running in debug log mode so don't have anything more thorough.
I'm just wondering what kind of error this is and if I've got a good rip or not. Usually the program gives more info on problem discs, usually in the form of hash check errors (with offset numbers) or full on 'Scsi error/uncorrectable error'. It usually states which playlist file the error occurred on also which is very helpful.
I've noticed with hash check errors, if there are not too many and the drive gets past the problem area the rip continues, but with the other types it usually stops and backup failed comes up.
What I'm trying to figure out is if the encountered read error but backup complete message I got above means I got a good copy with no corrupt data (but maybe at some point it had encountered a problem area but managed to re-read) or whether it's another form of failed copy and I need to re-rip.
What kind of error is this?
Re: What kind of error is this?
The skipped dummy fdat is normal on that disc
The read error is not
But if you got only one only a very small section of the video will be corrupt usually show up as blurry blocks
simon_ldt
Thanks, as I expected (although was hoping I wouldn't have to re-rip).
Will try it again and put on debug log this time. Just wish I knew which playlist file the error occurred on as this disc in particular has lots of smaller files a few GB each (as it seamless branches the 2 different cuts) and I could have tried to extract the errored file another way.
