Blair Witch (2016) UK (Red Box)
Kettykrueger
Post by Kettykrueger » Thu Feb 09, 2017 6:41 pm
Hi
Does anyone know which playlist is correct with this version? I've tried the suggestion on the thread for the US release but none work.
Many thanks in advance.
Kettykrueger
Re: Blair Witch (2016) UK (Red Box)
Post by Kettykrueger » Tue Feb 14, 2017 7:42 pm
Anyone :?
Kettykrueger
Post by Kettykrueger » Thu Feb 16, 2017 9:47 pm
Is there anything I can do to determine this myself?
Post by Woodstock » Thu Feb 16, 2017 11:49 pm
There are ways to determine it, but... whether or not YOU can do it depends upon how ambitious you are and whether or not you have the tools needed.
Searching the forum for "obfuscation" will give you a lot of hits, some of which explain how to figure it out. There are also YouTube videos on how to do it with certain software packages installed on your computer (one from Microsoft, the other a commercial Bluray player package).
The general description is using a software package that is "allowed" to find the correct file, and watch what file it opens when you hit play. It gets more complicated than that, though...
Kettykrueger
Post by Kettykrueger » Sat Feb 18, 2017 10:21 pm
Woodstock wrote:There are ways to determine it, but... whether or not YOU can do it depends upon how ambitious you are and whether or not you have the tools needed.
Cheers for that. So I guess my next question is; will MakeMKV ever make it possible to determine which track is correct?
Post by Woodstock » Sun Feb 19, 2017 2:02 am
If you have Java installed on your computer, MakeMKV will TRY to determine which track is the proper one. It doesn't always work; When it doesn't, Mike asks that you send some information to him. Discussion of what is necessary is found here: http://makemkv.com/forum2/viewtopic.php?f=8&t=14330
Some people can't find the "right play list" when it is given to them, because MakeMKV has moved it to the top of the list already.
Kettykrueger
Post by Kettykrueger » Sun Feb 19, 2017 8:56 pm
Woodstock wrote:If you have Java installed on your computer, MakeMKV will TRY to determine which track is the proper one. It doesn't always work; When it doesn't, Mike asks that you send some information to him. Discussion of what is necessary is found here: http://makemkv.com/forum2/viewtopic.php?f=8&t=14330
Thank you so much. I installed Java and it found the right playlist.
Thanks agin, dude.
mark35
Post by mark35 » Tue Dec 01, 2020 2:27 pm
Could you please disclose the correct MPLS?
