Batman: Death in the Family
boe_d
Post by boe_d »
Anyone have any trouble decoding it? When I select 300.mpls it is 2 chapters, 2.9GB, 31 minutes long and has the story of SGT Rock and Adam Strange. I also found an 8 minute movie with Robinhood 350mpls. I do see a lot of debug code 233
boe_d
Re: Batman: Death in the Family
Post by boe_d »
Sorry, I should have posted this in the Bluray section, not UHD. Not sure if this helps.
MakeMKV v1.15.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\jmillerick/MakeMKV_log.txt
The program can't find any usable optical drives.
DEBUG: Code 47427 at &@hPd.(@!4AlrT:121263153
DEBUG: Code 4779 at &@hPd.(@!4AlrT:29394965
DEBUG: Code 4779 at &@hPd.(@!4AlrT:121263153
DEBUG: Code 47427 at &@hPd.(@!4AlrT:29394965
AACS directory not present, assuming unencrypted disc
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
File 00120.mpls was added as title #1
File 00121.mpls was added as title #2
Title 00140.mpls is equal to title 00120.mpls and was skipped
Title 00141.mpls is equal to title 00121.mpls and was skipped
File 00300.mpls was added as title #3
File 00310.mpls(1) was added as title #4
File 00314.mpls was added as title #5
File 00350.mpls was added as title #6
Title #00352.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00359.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00368.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00375.mpls has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00400.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00401.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00402.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00403.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00404.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00405.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00406.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00407.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00408.mpls has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00408.mpls(2) has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00409.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00410.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00411.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00412.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00413.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00414.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00415.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00416.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00417.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00418.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00419.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00420.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00421.mpls was added as title #7
Title 00802.mpls is equal to title 00120.mpls and was skipped
File 00811.mpls was added as title #8
Title 01515.mpls is equal to title 00121.mpls and was skipped
Title #01007.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01063.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01064.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01065.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01066.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01067.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01068.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01069.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01070.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01071.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01073.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01074.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01076.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01086.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01143.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01144.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01206.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01219.m2ts was added as title #9
Title #01220.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01221.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01222.m2ts was added as title #10
Title #01223.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01224.m2ts was added as title #11
Title #01225.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01226.m2ts was added as title #12
Title 01227.m2ts is equal to title 00811.mpls and was skipped
Title #01229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01230.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01233.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01243.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01244.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01245.m2ts was added as title #13
Title #01246.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01247.m2ts was added as title #14
Title #01250.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01251.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01252.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01253.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01254.m2ts was added as title #15
Title #01257.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01258.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01259.m2ts was added as title #16
Title #01260.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01261.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01264.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01265.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01266.m2ts was added as title #17
Title #01267.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01268.m2ts was added as title #18
Title #01271.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01272.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01273.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01274.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01275.m2ts was added as title #19
Title #01278.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01279.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01280.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01281.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01282.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01283.m2ts was added as title #20
File 01284.m2ts was added as title #21
File 01285.m2ts was added as title #22
File 01286.m2ts was added as title #23
File 01287.m2ts was added as title #24
Title #01290.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01292.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01293.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01294.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01295.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01296.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01297.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01298.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01299.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01300.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01301.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01302.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01303.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01304.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01305.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01306.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01307.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01308.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01309.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01310.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01311.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01312.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01313.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01314.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01315.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01316.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01317.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01318.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01319.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01320.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01321.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01322.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01323.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01324.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01325.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01326.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01327.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01328.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01329.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01330.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01331.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01332.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01333.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01334.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01335.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01336.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01337.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01338.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01339.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01340.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01341.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01342.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01343.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01344.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01345.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01346.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01347.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01348.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01349.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01350.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01351.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01352.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01353.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01354.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01355.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01356.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01357.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01358.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01359.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01360.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01361.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01362.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01363.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01364.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01365.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01366.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01367.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01368.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01369.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01370.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01371.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01374.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01375.m2ts was added as title #25
DEBUG: Code 233 at TC0wIz0eZW8HaReRuQGlMHEz:0
DEBUG: Code 233 at CnOAnlZLONQnq1WHoEV0elw4:0
DEBUG: Code 233 at 86BCozfFS3HyBI0oRAFPucRl:0
DEBUG: Code 233 at xHwdcxgx/VnnxKWuqgrpH9xN:0
DEBUG: Code 233 at sfGnQUYYHbs5K7wCJxkqgffp:0
DEBUG: Code 233 at PVPJxrnGaeH9dprqpi9d04SV:0
DEBUG: Code 233 at fCwT6b2V1B1o30ZhNQ5fnsG5:0
DEBUG: Code 233 at Wfi75EsTOzHIQU54lOWWbxLr:0
DEBUG: Code 233 at ZVI11BElAibLMiFoHcotnXR3:0
DEBUG: Code 233 at sZ/qF5EK20wdVAEx/5tHrCCV:0
preserve
Post by preserve »
According to the Blu-ray.com review, this is a “choose your own adventure” interactive movie where you choose what to do.
There is apparently a 31-minute “linear version” that includes an audio commentary, so that may be the closest thing to a normal version.
Using: ASUS BW-16D1HT 3.00
boe_d
Post by boe_d »
