Lord of the Rings + The Hobbit 4K (Finally!)
Cannikin
Re: Lord of the Rings + The Hobbit 4K (Finally!)
#31 Post by Cannikin » Mon Nov 30, 2020 7:52 pm
Cannikin wrote:
Mon Nov 30, 2020 7:26 pm
Maybe it's possible to split part 1 right before the last 3 black seconds, and split the second part after the first 2, then combine the resulting individual files to have a seamless cut between them? Hmmm...
I can confirm this just worked with the 1080p versions! I split the first part at 1:45:38 and split the second at 00:00:02 and then stitched them back together and it worked, seamless transition!
It's possible that a couple of frames on either side of the cut were removed...I'll have to play back the originals in a player that shows frame count, or import into Davinci Resolve and get them there, then do a more accurate cut.
Once the 4K ones come this week I'll try again and make sure that DV and DA are preserved and then report back.
Trickyd-1
#32 Post by Trickyd-1 » Mon Nov 30, 2020 7:57 pm
Thanks for your insight Cannikin. I might try cutting in mkvtoolnix and see what the result plays like.
#33 Post by shawnc22 » Mon Nov 30, 2020 8:39 pm
Trickyd-1 wrote:
Mon Nov 30, 2020 7:27 pm
No they are on their own discs and the bitrate is slightly lower.
Bit rate, Fellowship of the rings :
Theatrical: 53.5 Mb/s
Extended:67.9 Mb/s
Ah got it. What're most of you guys doing? Ripping both for completions sake?
#34 Post by SamuriHL » Mon Nov 30, 2020 8:42 pm
I'm only going to rip the extended editions. Don't have the space for anything else.
charlie62
#35 Post by charlie62 » Tue Dec 01, 2020 2:08 am
The two towers part 1 won't decrypt for me dump sent
NickNickNick
#36 Post by NickNickNick » Tue Dec 01, 2020 2:42 am
Is each extended movie around 200Gbs merged?
PaulCB
#37 Post by PaulCB » Tue Dec 01, 2020 3:00 am
16tb drives are super cheap (per TB) right now. $338 on amazon...
CrazyDymond88
#38 Post by CrazyDymond88 » Tue Dec 01, 2020 3:31 am
Mine range from 113Gb to 133Gb
#39 Post by SamuriHL » Tue Dec 01, 2020 3:34 am
Not the issue. My nas is currently maxed out and has around 2.5tb left which will be gone soon. I need to build a bigger nas but it costs money.
Cannikin
#40 Post by Cannikin » Tue Dec 01, 2020 3:56 am
What kind of NAS do you have? I have a Synology 1819+ with 8 drives all 10TB. It would be cheaper to buy a 5-bay add-on drive and get 5 10TB drives for than than to upgrade the existing 10TB drives to 16TB. I'm at 72% capacity, 15TB left. :o
#41 Post by SamuriHL » Tue Dec 01, 2020 4:45 am
4 bay synology with 10tb drives.
#42 Post by dcoke22 » Tue Dec 01, 2020 4:55 am
The Data Hoarder crowd over on Reddit (https://www.reddit.com/r/DataHoarder/) likes to shuck drives out of external storage. These days <$200 for a 14TB drive seems to be what people go for. You probably won't get a 7200 RPM enterprise grade drive, but that might not matter.
PaulCB
#43 Post by PaulCB » Tue Dec 01, 2020 5:20 am
Yeah, full NAS is a pain. Looked hard at getting one for a long time but that issue is why I decided to stick with keeping all my drives in my main system. Just a ton easier to deal with adding space and making adjustments.
And I certainly need all that space as I'll be keeping my Theatrical and Extended BR versions of LOTR & Hobbit when I add both of these UHD versions as I keep the BR version for family streaming and non-UHD devices.
#44 Post by shawnc22 » Tue Dec 01, 2020 6:00 am
Yep I have a 4 bay QNAP with 8TB shucked drives that was starting to run out of space, so I just got another 6 bay during black Friday with 4 12TBs in there so far. I think this should be good for at least another few years (hopefully).
Guinness
#45 Post by Guinness » Tue Dec 01, 2020 6:02 am
This is why btrfs is the best for storing large media collections. It is EXTREMELY easy to add/remove/expand the raid array live online without interruption. One of your old 8TB drives needs to be replaced with some 16TB drives? btrfs replace, bam, done.
raid1c3 for metadata, raid6 for data. Works great, been stable for a few years now.
