Backup option greyed out for DVDs but not for blu ray
morbius
#1 Post by morbius » Tue Mar 12, 2019 5:59 pm
Does makemkv not have the option to create a decrypted backup for DVDs ? Just noticed it's not available for me (I know that you must not "open" the disc first). The option works for blu rays so why not DVDs? Seems very odd. Looks like I'm about to dust off my ancient copy of DVD Shrink!
Re: Backup option greyed out for DVDs but not for blu ray
#2 Post by Woodstock » Tue Mar 12, 2019 11:41 pm
Backup is a Bluray-only function.
morbius
#3 Post by morbius » Wed Mar 13, 2019 8:46 am
So I gathered. Can anyone advise why this functionality is not enabled for DVDs but it is for blu rays ? Does not seem intuitive.
#4 Post by Woodstock » Wed Mar 13, 2019 2:19 pm
Because when BD support was added, there were no programs that would generate an unencrypted copy of a Bluray, but there were a LOT of them for creating unencrypted DVD ISO files. There still aren't a lot of them for BD.
I just think Mike didn't want to duplicate what was already out there for free.
morbius
#5 Post by morbius » Wed Mar 13, 2019 4:49 pm
Ho hum. I run a registered version of makemkv and I think it's outstanding and Mike is a wizard, just had not occurred to me that there would be less functionality with DVD than with bluray. I don't have much need for full disc back up so I still think makemkv is fantastic, but I did stumble on this, assuming it was a glitch rather than by design.
renfield
#6 Post by renfield » Wed May 15, 2019 5:43 pm
I gotta say, I too am disappointed.
What is a recommended dvd backup program? Because makemkv complains about mine. :(
One that understands and doesn't fail on corrupt sectors and other schemes.
#7 Post by Woodstock » Wed May 15, 2019 6:38 pm
I've used dd on Linux to create encrypted ISOs. I'm remembering one from years or so ago called "BDLOT" make ISOs on Windows machines, with optional decryption, but it's been unsupported for about a decade.
renfield
#8 Post by renfield » Thu May 23, 2019 4:06 pm
yeah that doesn't work because it's easily defeated by even the most simple copy protection
renfield
#9 Post by renfield » Fri Jul 12, 2019 12:59 am
I'm using makemkv for mac.
Just came across my first DVD that doesn't work correctly.
I use DVDFab for mac. I copy full discs to a folder structure. I usually keep the PathPlayer option on, so DVDFab can scan and remove copyright and other startup messages. It does this by rewriting the first VTS or something like that.
Whether I keep PathPlayer on, ie allow DVDFab to edit the IFO and first VTS, or turn PathPlayer off (which should copy the IFO and VTS as-is), in either case makemkv does not find the first title at all during its scan. It starts at title 3 in the log output.
Also for both of these cases, vlc does work and navigates the DVD menu and plays title 1 correctly. (title 2 is the 35s copyright message -- this is skipped by vlc for either setting of PP. vlc also skips the copyright when playing from the actual disc.)
If I change DVDFab to create an ISO, makemkv finds all the titles when opening the iso.
Now, I don't know if DVDFab is making a mistake here, but given that vlc can navigate the dvd menu correctly, while makemkv cannot, I suggest that this is a bug in makemkv. Even if the ifo is in fact corrupt somehow, vlc has no difficulty with it.
I'm very interested in getting this fixed because I prefer to archive as folder structures, not ISOs. I can make available the entire disc, the original and DVDFab-saved IFO, VTS, whatever.
smartieyoung
#10 Post by smartieyoung » Fri Jul 26, 2019 8:32 pm
I find that i use makemkv for bluray and 4k rips,i have seen many good dvd rip programs, i personally use win x dvd ripper platinum and it does really well.however since this is makemkv forum that is all i will say on program recommendations.not that im trying to be elitist or anything.i found everything i needed on internet including makemkv by searching the internet.
Trubes
#11 Post by Trubes » Sat Aug 08, 2020 9:50 pm
I use RipIt for macOS. It's an older app but still runs great under Catalina.
http://thelittleappfactory.com/ripit/
daraclark
#12 Post by daraclark » Wed Aug 26, 2020 8:04 am
Should I use WinX DVD Ripper Platinum to backup my DVDs to folder or MP4 digital video format? The programs offers a few backup options.
krole
#13 Post by krole » Sun Nov 29, 2020 5:02 pm
Is there any chance of DVD backup being added? I think Backup option for DVDs is worth adding, as there aren't many programs left that do this and are still supported.
#14 Post by Woodstock » Sun Nov 29, 2020 10:07 pm
Kind of doubt it, but it could happen.
As for programs that can make ISOs, the program "dd" that comes with Linux and MacOS is still out there, and even runs on Windows 10 in WSL. It's got simple syntax, so long as you know the device name for your optical drive.
dd if=/dev/cdrom of=/location/of/output.iso
The result can be played in most DVD-aware players.
Ezatoka
#15 Post by Ezatoka » Mon Nov 30, 2020 5:10 pm
Is dd even able to copy a DVD with CSS?
And I guess, MakeMKV is not much possible to make full DVD backups because of the menus. Maybe there just wasn't a reason to make it able to read menus at all.
