Use Audio from multiple options
Davidk
Post by Davidk »
I am quite new to this. I was wondering if there was a way to combine audio tracks from multiple options that appear when remuxing. I can't seem to unselect the video only and keep the audio track.
Thank you in advance.
David
Re: Use Audio from multiple options
MakeMKV isn't going to let you deselect the video, but you can remove it later with mkvmerge (part of mkvtoolnix if you search for it).
Combining audio tracks will be a bit more involved, depending on what you're actually trying to do.
