Seems to bog down in a loop during cell detection....
MakeMKV v1.6.3 linux(x64-release) started
Debug logging enabled, log will be saved as /tmp/MakeMKV_log.txt
Title #0 was added (21 cell(s), 1:22:24)
Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:02:30)
Title #6 was added (1 cell(s), 0:06:38)
Title #7 was added (1 cell(s), 0:08:18)
Title #8 was added (1 cell(s), 0:08:08)
Title #9 was added (4 cell(s), 0:18:56)
Title #10 was added (10 cell(s), 0:10:16)
Title #11 was added (4 cell(s), 0:04:55)
Title #12 was added (7 cell(s), 0:05:21)
Title #13 has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Jumped to cell 2 from cell 3 due to cell commands (structure protection?)
Loop detected. Possibly due to unknown structure protection.
CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Fake cells occupy 74% of the title - assuming fake title
Fake cells occupy 77% of the title - assuming fake title
Fake cells occupy 75% of the title - assuming fake title
Title #37/3 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/4 has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/5 has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/6 has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/7 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/8 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/9 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/10 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/11 has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/12 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/13 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37/14 has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /tmp/THE_FOX_AND_THE_HOUNDAny idea if this behaviour is normal ? (of all the dvd's archived by MakeMKV, this is the only one to spin in circles like this). The MKV seems to be fine.
I can post VTS/IFO's if it'll help...
