webbos
#1
Post
by webbos » Sun Nov 29, 2020 4:07 pm
Hello
New to MakeMKV, greetings to everyone
Long story short, just acquired an "UHD Friendly" drive. Works within MakeMKV and DVDFab - actually, it's ASUS BW-16D1HT
Is there any way to get ISO or folder-rips (1:1 backups) of an UHD by using MakeMKV ?
Thanks and regards
#2
Post
by Woodstock » Sun Nov 29, 2020 4:36 pm
MakeMKV will not make ISOs on its own. While you could use the file structure of a MakeMKV backup to author a new ISO, it would not be a "1:1 copy".
And yes, you would need BD authoring software to do it.
#4
Post
by Coopervid » Sun Nov 29, 2020 5:21 pm
I have to correct myself to be precise. SamuriHL's method will make a protected ISO.
If you want an unprotected ISO you have rip to folder with MakeMKV and then read these folders in with Imgburn and create the unprotected ISO.
But still no authoring software required.
#5
Post
by SamuriHL » Sun Nov 29, 2020 6:00 pm
ImgBurn falls into the "BD Authoring" category. My script will make a protected ISO that's 1:1 with the disc. Alternatively, I have a script that can make a decrypted folder backup and then use ImgBurn to master that to an ISO. This is NOT a 1:1 copy but it doesn't modify the disc structure in any way.
#6
Post
by Coopervid » Sun Nov 29, 2020 6:29 pm
C'mon Sam. Making Imgburn a "BD authoring software" is more than a stretch. Such software picks individual video files and creates a BD structure from scratch. However, Imgburn picks the existing BD structure and makes an ISO from it.
Anyway -what counts is the successful result.
#7
Post
by SamuriHL » Sun Nov 29, 2020 8:07 pm
I'm NOT going to argue with you.
