mossman1120
Re: Ultimate UHD Drives Guide Updated 2020
Post by mossman1120 »
Billycar11 wrote:
Tue Nov 24, 2020 12:49 pm
MartyMcNuts wrote:
Tue Nov 24, 2020 10:17 am
mossman1120 wrote:
Tue Nov 24, 2020 4:54 am
In case one has to RMA a dead drive that came with 1.04
If it needs RMAing, just put 1.05 on it.
This ^
I didn't see 1.05 listed on the LG website. Is there an factory download location for it? Thanks.
mossman1120 wrote:
Tue Nov 24, 2020 8:59 pm
This ^
You could just use the MK version of 1.05. LG don't seem to have downloadable firmwares anymore. I think they have an update tool that can update the firmware from their servers.
inkwell84
Post by inkwell84 »
My LG NS60 arrived. It is a 5/2020 manufacture date with 1.02 ROM and SVC CODE NS60.
Question 1: Based on the mfr date, rom, and svc code, is there anything I should worry about before attempting flash?
Question 2: This guide recommends I flash to 1.02 MK but the MK pack has the 1.03 MK firmware in the HL-DT-ST folder, and the 1.02 MK firmware in the "old" folder... should I be flashing to the "old" 1.02 MK ?
Roca68
Post by Roca68 »
I have a LG WH14NS40 with firmware 1.05. I have tried to change the firmware using the command prompt process to change the firmware to each of the following but nothing seems to change even thought the process seems to complete.
MK\old\HL-DT-ST-BD-RE_WH14NS40-NS50-1.03-NM00600-211711211658.bin
MK\HL-DT-ST\WH14NS40-NS50\HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin
MK\HL-DT-ST\WH16NS60\HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin
MK\old\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Please help as my read speeds are slow.
Post by d00zah »
Windows? Try the SDFtool Flasher w/ 1.05MK FW & check 'Enc'.
matrixprime
Post by matrixprime »
Question about drive flashing. I'm running a WH14NS40 drive. According to MakeMKV I'm already at revision 1.02, however the recommended firmware thread suggests:
WH14NS40 > WH16NS60 1.02 MK
I believe I used the tool correctly, but MakeMKV still shows the drive as WH14NS40 and lists Firmware type as "Original (Unpatched)" so is that correct? I'm still running into issue where only some UHD will rip/copy. It continues to be a DEBUG Code Error.
Saving 1 titles into directory C:/Users/ajaco/OneDrive/Desktop/MakeMKV Output
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '27711369216'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '27711369216'
DEBUG: Code 3221225488 at "-3g'LSG4y)fI{BUb}:29395149
DEBUG: Code 101000192 at "-3g'LSG4y)fI{BUb}:29395149
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:29395471
DEBUG: Code 0 at j_2*gIk0SDRBlYdA[&(.:29394068
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:213131157
DEBUG: Code 0 at )|-Dt0UfP<I#NHOVBsLn:121262647
DEBUG: Code 13530942 at )|-Dt0UfP<I#NHOVBsLn:121261773
DEBUG: Code 0 at G-:2J:LOr}j3QY>HbnolD:213137091
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file C:/Users/ajaco/OneDrive/Desktop/MakeMKV Output/Transformers The Last Knight_t00.mkv
0 titles saved, 1 failed
matrixprime wrote:
Sun Nov 29, 2020 2:09 am
you didnt flash it to WH16NS60 but that does not really matter for read errors the NS60 firmware just reads faster and has no sleepbug. you have either a bad disc or bad drive.
try
clean disk
new disc
optional clean laser
new drive
Roca68
Post by Roca68 »
d00zah wrote:
Sat Nov 28, 2020 7:52 pm
Thanks, that worked after a fresh install of MakeMKV
matrixprime
Billycar11 wrote:
Sun Nov 29, 2020 4:40 am
try
clean disk
new disc
new drive
I'm wondering if the drive is the issue. This is my third brand new UHD disc I bought on Black Friday and only 1 of them ripped. I'll try cleaning first and then a new drive. Thanks for the info!
sofakng
Post by sofakng »
I've been using an LG WH16NS40 for a while and I think it's dying. It's making a terrible grinding noise and MakeMKV is reporting hash errors.
I've ordered a replacement from Amazon (same model) so as long as it has SVC50 (or higher) and MT1959 I should be OK, right?
Also, which firmware is recommend to flash? The original post says "1.02MK" but I'm guessing this has the sleep bug?
sofakng wrote:
Tue Dec 01, 2020 3:37 pm
The guide recomends WH16NS60 1.02MK. There is no sleep bug in "official" UHD drive firmware.
sofakng
Post by sofakng »
Oh, sorry ... I think I understand now.
The LG WH16NS40 is "UHD Friendly" but is recommended to cross-flash (?) to LG WH16NS60 which is "UHD Official" (and therefore doesn't have the sleep bug).
By the way, I seem to remember when I first flashed my WH16NS40 that you had to extract drive-specific calibration (?) values before you cross-flashed a different firmware. Do the new flashing utilities also take care of this automatically?
sofakng wrote:
Wed Dec 02, 2020 2:34 pm
Yep, no need to do any of that if you use a windows flasher.
clearcreation
Post by clearcreation »
I recently bought a WH16NS40 NS50 drive, that I've installed internally in a Windows 10 system. I'd like to be able to rip 4K discs as well as burn CD/DVD/Blu-ray discs. While for ripping I'll mostly be using MakeMKV, I'd like the option to use other programs as well.
To this end, what's the best firmware for these purposes, using SDFtool? Does the WH16NS60 1.02MK firmware from the first post prevent any of my above requirements?
If I need a different firmware, would I instead flash 'HL-DT-ST-BD-RE_BH16NS40-NS50-1.04-NM01701-211901041338'? If so, do I then leave it on that firmware or flash another one after such as 'HL-DT-ST-BD-RE_WH16NS40-NS50-1.03-NM00600-211711211653'?
I appreciate any assistance!
The drive details are:
Product: BD-RE WH16NS40
Revision: 1.04
Serial number: <removed>
Firmware date: 2119-01-04 13:48
sofakng
Post by sofakng »
I've also just purchased a replacement LG WH16NS40 drive and it came with v1.04 firmware.
I'm not sure if I did the correct procedure, but I first flashed HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440 and then cross-flashed to HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.
The original post recommends LG WH16NS60 v1.02, but it looks like only v1.03 is available in the MK pack.
I'm not sure if it's related, but I'm getting lots of corrupt file errors on this brand new drive and brand new discs (see this thread).
EDIT: I've tried to rip my second disc (Coco UHD) and it didn't have corruption errors, but had about 10x "AV sync issues" ?
