John Wick: Chapter 2 ripping errors on UHD
RScottyL
Post by RScottyL »
I just got the 3 disc UHD set in and trying to rip all three movies.
JW1 and JW3 ripped just fine, but JW2 giving errors:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '14129952768'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '14129952768'
Is anyone else getting this?
Re: John Wick: Chapter 2 ripping errors on UHD
RScottyL wrote:
Sat Oct 17, 2020 4:38 am
Your drive is having trouble reading the disc. Before doing anything else, try giving the disc a proper clean.
RScottyL
Post by RScottyL »
I will give that a try, but it was a brand new disc that I took out of the package!
WAYFLIX
Post by WAYFLIX »
I had no issues backing up JW 2.
METDeath
Post by METDeath »
I also have the same error using my ASUS BW-16D1HT 3.02, tried a good clean, no dice.
Edit: Also from the 4K three pack.
izike
Post by izike »
Same exact issue, purchased the John Wick 3-pack UHD, Disc 1 and 3 rip fine, Disc 2 gives SCSI errors. I even exchanged the set with a new set, same issue. Did anyone ever find a solution for this? Thanks!
