ergeeg wrote: Tue Nov 17, 2020 1:22 am Yes, I am using a Sata to Sata USB adapter. I loaded the SDFtool tool, but nothing happens. When I hit start nothing happens.
I would say your adapter is the problem. Check the Ultimate UHD guide for the one's to get.
almus
Post by almus »
Please help, if you can.
My drive is an LG:
Product: BD-RE BH16NS40
Revision: 1.03
Serial number: SIK9GE6E9152
Firmware date: 2117-11-20 19:43
Highest AACS version: 65
Firmware version: 1.03
(I am not sure if that's exactly what it looked like before my flashing attempts though, I am sure it is a BH16NS40 and came with a 1.03 firmware)
The drive was working fine but I attempted to downgrade the firmware to 1.02 for UHD support using ASUS_ODD_FW_Changer_(Modified)
The firmware flash seemed to be successful however now the drive will not recognize that a disk in inserted at all. MakeMKV and windows both just tell me "no disk inserted"
Is there any way I can recover? Any suggestions on the steps to take?
Thank you!
almus
Post by almus »
Update to the previous post. I downloaded and tried the LG official firmware tool, in hopes that maybe I could just restore it to how it was before. (BH16NS40_SVC Code NS50.zip)
Running that seems to go through the process fine except it fails at the very end with something about the drive being in recovery mode. This did not fix it, I'm at the same place I was at before but I figured the extra data point could help.
Digital moe
Post by Digital moe »
I have a Asus BW-16D1HT running 3.02 and recently started to see it was having issues reading new discs and so have been looking at upgrading the firmware to 3.10.
Just want to check do I just run the Cross-Flash tool and select ASUS-BW-16D1HT-3.10-WM01601-211901041014 in the MK folder? Seems very simple just wanted to check I wasn't missing anything?
Digital moe wrote: Thu Nov 26, 2020 12:35 am I have a Asus BW-16D1HT running 3.02 and recently started to see it was having issues reading new discs and so have been looking at upgrading the firmware to 3.10.
Yep, that's it...
almus wrote: Thu Nov 19, 2020 3:19 am Update to the previous post. I downloaded and tried the LG official firmware tool, in hopes that maybe I could just restore it to how it was before. (BH16NS40_SVC Code NS50.zip)
How old is your drive? The things you are describing make it sound as though it is older than late 2015.
thelad
Post by thelad »
Joined forum just to say thanks for this. My ASUS drive was 3.3 and supposed to be friendly, used your program dropped it to 3.2 and DVDfab seems to work(don't worry only a trial) I'll be testing makemkv next :D
ksyolsen
Post by ksyolsen »
Hello!
I just purchased an LG BP50NB40 today and attempted to follow the guide you have posted, but unfortunately, I keep getting "Update Failure #5" and can't find much of anything online that would explain what I need to do to solve this issue.
Here is the info currently shown on MakeMKV:
OS device name: E:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK0DK8SE2245
Harware support: Yes
Firmware support: No
I used the HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917 firmware file, and get "Update Failure #5"
Any help would be appreciated!
ksyolsen wrote: Fri Nov 27, 2020 9:48 pm Hello!
OS device name: E:
Revision: 1.03
Your drive comes with 1.03 which is an encrypted firmware. This flasher does not work with encrypted firmware. Please use the new SDFtool Flasher.
ksyolsen
Post by ksyolsen »
MartyMcNuts wrote: Fri Nov 27, 2020 11:51 pm
OS device name: E:
Revision: 1.03
Thank you!
vseven
Post by vseven »
MartyMcNuts wrote: Sun Feb 17, 2019 3:30 am Below is the link to the modified ASUS FW Flasher + Downgrade Enabled Firmware + the latest MK firmware pack (20/07/2020):
Just wanted to add my 2 cents and say thank-you. I have a LG USB 2.0 External WP50NB40 that I got a couple years ago that was running firmware 1.01. Just used this along with the "HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin" file and it updated without issue and now lists as patched with 1.03:
I don't think this drive is UHD capable but at least it's upgraded and seems to rip faster (was taking 45 - 50 min and now its closer to 35).
vseven wrote: Wed Dec 02, 2020 4:08 pm
I assume this drive is the same as the BP50NB40?? If so, you should be able to make it UHD capable by cross-flashing to BP60NB10 1.00 MK firmware. If you decide to try it, I suggest you use the SDFtool Flasher to do so.
vseven
Post by vseven »
MartyMcNuts wrote: Thu Dec 03, 2020 3:06 am I assume this drive is the same as the BP50NB40?? If so, you should be able to make it UHD capable by cross-flashing to BP60NB10 1.00 MK firmware. If you decide to try it, I suggest you use the SDFtool Flasher to do so.
Not positive, it's a slim drive that came in a LG USB enclosure, I've only seen it as WN50NB40. But I figured why not try and using the SDFtool Flasher along with HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin and I now have this:
Product: BD-RE BP60NB10
Revision: 1.02
Firmware date: 2120-05-07 09:35
Highest AACS version: 60
Firmware version: 1.02
Does that mean I should be able to rip UHD now?
shaferandrew
Post by shaferandrew »
Hi all,
I wanted to thank everyone for their great advice in here. I bought a WH14NS40 from Amazon this week and it arrived today with a mfg date of July 2020 and the 1.05 firmware. I used the SDFtool to flash it to HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-NM00900-212005061444.bin (checking enc?). I then rebooted and used the tool to flash it to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin (in the "old" directory, also had to check enc? to flash correctly). I rebooted. It now reports itself as a WH16NS60 in Windows/MakeMKV/etc. I have successfully used it to rip Blu-rays. I do not have a UHD disc to check that functionality but I assume that should work (because of the 1.02 firmware?).
vseven wrote: Fri Dec 04, 2020 7:45 pm
Revision: 1.02
Don't know about firmware 1.02. I normally flash BP60NB10_1.00-MK.
