IT FREAKIN WORKS!!! The first response on this post actually works. I followed this video to the T and it works beautifully. I didn't know they encrypted the firmware now. He discussed my exact issue and solved it!! Thank you so so much!!!
Ultra HAXOR GUIDE V2 for encrypted firmware
https://www.youtube.com/watch?v=jyQV1aPlbow
Ultimate UHD Drives Guide Updated 2020
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
I just recently bought a 2nd UHD Drive as a backup to my main one. I've done the flashing process 2 times on two other drives I own using the ASUS flashing tool. However, this new batch of LG drives comes pre-loaded with the 1.03 firmware. I was able to RIP a Blu-ray using MakeMKV, however the Libre features aren't enabled. I want this flashed correctly like my other drive that I flashed. The other one I bought had version 1.02, but I upgraded it to the modified 1.03. It works like a beaut!
In short, how do I flash this new drive that I have?? This is the 2nd one that I've bought off of Amazon in 1 weeks and I'm having the same issue. I returned the other one cause I thought it was messed up. Below is a link of the 2 softwares I've used to try to flash this drive. I know I'm not flashing to the 1.03 that I'm doing the 1.00 version. Regardless, I get the same error.
LG WH16NS60 Flashing Issue
https://www.youtube.com/watch?v=emyyQoY ... e=youtu.be
Drive with Firmware Issues
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KLZK7LA4007
Firmware date: 2120-05-08 10:10
Harware support: Yes
Firmware support: No
Firmware version: 1.03
Drive that I flashed successfully 3 weeks ago. (Original FW 1.02)
OS device name: F:
Revision: 1.03
Serial number: KLJK59D5702
Highest AACS version: 68
[FIXED] LG WH16NS60 Errors - Updating Failure #5 or CheckSum is Mismatched...
joeyfun
Re: LG WH16NS60 Errors - Updating Failure #5 or CheckSum is Mismatched...
Read my guide : https://www.makemkv.com/forum/viewtopic ... 16&t=19634
joeyfun
Thank you so so much for this!! It really worked and helped me out!!Billycar11 wrote: Fri Nov 27, 2020 6:45 pm Read my guide : https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Burnsy01
Re: [FIXED] LG WH16NS60 Errors - Updating Failure #5 or CheckSum is Mismatched...
I took the plunge today and spent $90 on the LG WH16NS60 at Microcenter. Came with the Cyberlink disk. Met the requirements: 2020 build, 1959, 1.03, NS60. I assumed the firmware was encrypted.
Was nervous because the new firmware file didn't have a MK in the name and it took me one try to determine I needed to manually add the .bin file extension. But, I am LibreDrive enabled on 1.02. Thanks to everyone who put in the time and research to accomplish what I never could have. Dave
