Hi sorry, should have been more precise, this is in relation to PGS subs on Profile 8 with TrueHD only on the Z9X, I also believe some people are having problems with subs both srt and pgs if they are in the container on some titles on the Shield via Plex.ghostshadow wrote: ↑Tue Nov 24, 2020 8:09 pmOk so thank you, TrueHD tracks and subtitles are problematic on DV, and what on zidoo?DaMacFunkin wrote: ↑Tue Nov 24, 2020 7:42 pmRemoving the subtitles doesn’t solve the stuttering problem in the Z9X with Dolby Vision and True HD, I have tried it, removing the subtitle or marking subtitle tracks as ‘default no’ does however stop the Z9X decoder from crashing during playback of profile 8 as you have found out.ghostshadow wrote: ↑Tue Nov 24, 2020 1:48 pmHello, little news. I made a mkv dv profile 8 file which didn't play on the Zidoo Z9x, with audio track and subtitle, it blocked the zidoo altogether.
With the help of a colleague (Ramutcho) who was able to test, by removing the pgs (subtitle) the mkv goes well in dv. It would be necessary to test on a mkv dv with atmos tracks if by removing the subtitles that does not solve the stuttering problem.
Spectre (forced subs) is one in particular.
