Which Drive should i buy? Pls Help :(
dekuna
Post by dekuna » Tue Nov 24, 2020 6:26 pm
Hello together.
Im new in the "business". I red a lot of posts in this forum but im still very confused. I want to rip some of my Blu-rays and DVDs to my Plex Server.
At the moment, I have no drive. I want to buy one wehere i can rip Blu-rays and DVDs and (if its possible) UHD Disk. But my priority is Blu-rays and DVDs.
I understand the "technical" part about LibreDrives but im not shure if one of this Drive's work for ripping Blu-rays and DVDs.
Now I'm not sure witch drive i should buy.
I did some research and cam up with this two:
ASUS BW-16D1H-U PRO:
https://www.digitec.ch/en/s1/product/as ... es-7195548
Verbatim Slimline:
https://www.digitec.ch/en/s1/product/ve ... s-10936185
or should I buy another Drive?
Thx
dekuna
Re: Which Drive should i buy? Pls Help :(
Post by Woodstock » Tue Nov 24, 2020 7:14 pm
If your reading brought you to the ASUS BW-16D1H-U PRO, you're reading the wrong places. This drive is not capable of doing BDXL, let alone UHD. It will work well for DVD and BD, though.
Post by d00zah » Tue Nov 24, 2020 7:25 pm
Might I recommend the 1st post of Ultimate UHD Drives Guide Updated 2020 ?
Specifically, the "Recommended UHD Drives to get:" section. All will do DVD/BR/UHD.
dekuna
Post by dekuna » Tue Nov 24, 2020 8:09 pm
Woodstock wrote: Tue Nov 24, 2020 7:14 pm If your reading brought you to the ASUS BW-16D1H-U PRO, you're reading the wrong places. This drive is not capable of doing BDXL, let alone UHD. It will work well for DVD and BD, though.
Hey Woodstock
Thx for your quick respons.
Ok after reading more Posts im just more confused :/
I would like to use an external Drive.
Lets lower my goals down to just use the Drive "out of the box" for ripping Blu-rays and DVDs. Can I use one of these "out of the box"?
Verbatim Slimline:
LG BP55EB40:
https://www.digitec.ch/en/s1/product/lg ... ds=614-653
Thx for your help.
FredBloggs007
Post by FredBloggs007 » Wed Nov 25, 2020 1:33 am
Hey dekuna. I've used the LG drive you mention for DVD and Bluray and have done around 500+ movies onto my Plex. Other than a possible hardware failure recently, it's been fine. I suspect the failure has been due to constant use whilst I've been archiving my collection.
Post by MartyMcNuts » Wed Nov 25, 2020 3:14 am
dekuna wrote: Tue Nov 24, 2020 8:09 pm
Hey Woodstock
Verbatim Slimline:
LG BP55EB40:
Thx for your help.
For UHD, I seriously doubt that any drive from anywhere can be used out of the box. They all need to be flashed to allow UHD ripping. As per previous comments, if you are interested in UHD at all, then the ASUS BW-16D1H-U PRO is a no go, as it will never be UHD capable. I am not sure about the verbatim drive but I believe the LG BP55EB40 can be flashed to work with UHD.
jonghotti
Post by jonghotti » Wed Dec 23, 2020 3:02 am
Oh contraire Mr. Nuts any drive purchased from me, you, Bill, Scott and Robin will arrive tested and 4K compatible right out of the box. Which is why if you don’t feel like messing with it yourself the next best thing is to support the independent brotherhood of MakeMKV drive providers you’ll feel good supporting nice humans like us 🤘
Post by MartyMcNuts » Wed Dec 23, 2020 4:12 am
jonghotti wrote: Wed Dec 23, 2020 3:02 am Oh contraire Mr. Nuts any drive purchased from me, you, Bill, Scott and Robin will arrive tested and 4K compatible right out of the box. Which is why if you don’t feel like messing with it yourself the next best thing is to support the independent brotherhood of MakeMKV drive providers you’ll feel good supporting nice humans like us 🤘
My previous comment was referring to him going to a store and buying a drive, though you are correct!!! :wink:
jonghotti
Post by jonghotti » Wed Dec 23, 2020 4:48 am
MartyMcNuts wrote: Wed Dec 23, 2020 4:12 am My previous comment was referring to him going to a store and buying a drive, though you are correct!!! :wink:
I know it was but I just couldn't help myself. Plus I hold the copyright to the phrase "works right out of the box", or is it the trademark? It's not the patent I know that! The domain name absolutely but it's turns out no one has the patience to type in www.worksrightoutofthebox.com! :)
