VarHD
Re: Ultimate UHD Drives Guide Updated 2020
#451 Post by VarHD » Tue Nov 17, 2020 7:41 pm
Can someone recommend or confirm what kind of cable I could use to connect a slim/laptop drive to a PC via USB (mini SATA -> USB)?
I bought an LG BU40N recently, don't have a laptop, was hoping that one of the two "approved" Unitek cables would work, but they have the full large SATA connectors. I need one for mini SATA. Just a cable, BTW, I don't want an enclosure.
fordprefect
#452 Post by fordprefect » Tue Nov 17, 2020 7:58 pm
Thanks,
I will need to wait then till I get the adapter. There is no way for makemkv on libreelec. Just want to be sure that I don't have unsuitable generation of the drive.
Thanks for the hint for macOS. I guess only thing I have to adapt is the path to this /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
#453 Post by d00zah » Tue Nov 17, 2020 8:08 pm
fordprefect wrote: Tue Nov 17, 2020 7:58 pm Thanks,
The current FW version looks to be recent enough (3.x), but if you don't see "Drive platform: MT1959"(MT1939 is too old), STOP!
fordprefect wrote: Tue Nov 17, 2020 7:58 pm Thanks for the hint for macOS. I guess only thing I have to adapt is the path to this /Applications/MakeMKV.app/Contents/MacOS/makemkvcon
Thought that would be 'close enough'.
fordprefect
#454 Post by fordprefect » Tue Nov 17, 2020 8:31 pm
d00zah wrote: Tue Nov 17, 2020 8:08 pm The current FW version looks to be recent enough (3.x), but if you don't see "Drive platform: MT1959"(MT1939 is too old), STOP!
Ok, if that should happen I can't expect it to work and would need to get a different drive, right?
Yes, absolutely fine thanks.
#455 Post by d00zah » Tue Nov 17, 2020 8:43 pm
fordprefect wrote: Tue Nov 17, 2020 8:31 pm Ok, if that should happen I can't expect it to work and would need to get a different drive, right?
Correct.
#456 Post by Billycar11 » Tue Nov 17, 2020 9:44 pm
VarHD wrote: Tue Nov 17, 2020 7:41 pm Can someone recommend or confirm what kind of cable I could use to connect a slim/laptop drive to a PC via USB (mini SATA -> USB)?
https://smile.amazon.com/gp/product/B01 ... UTF8&psc=1
bhampster
#457 Post by bhampster » Wed Nov 18, 2020 8:34 pm
Is this part of the guide a typo
WH14NS40 > WH16NS60 1.02MK
Seems odd to put the NS60 FW on the NS40
#458 Post by SamuriHL » Wed Nov 18, 2020 8:36 pm
No. NS60 is the best firmware if you're only using MakeMKV. It's very reliable, fast, and no bugs.
KTL03
#459 Post by KTL03 » Thu Nov 19, 2020 2:56 am
Seeing all the posts related to external adapter issues, I'm glad I have an original CM Stacker where I can fit up to 10 optical drives. 8) I just picked up a Feb-2020 built BW-16D1HT in retail box for cheap since the seller had reading issues when using PowerDVD. It came with 3.10 and immediately flashed it to the 3.10MK version with SDFTool, no problems with MakeMKV ripping a Blu-ray.
fordprefect
#460 Post by fordprefect » Sun Nov 22, 2020 5:58 pm
It worked perfectly under linux with the linked description. The command to run was plainly makemkvcon without any path etc.
First UHD rip seems to work fine too. Thanks for support.
mossman1120
#461 Post by mossman1120 » Tue Nov 24, 2020 3:50 am
I am trying to find a factory copy of the 1.04 version for a WH16NS40. I can only see 1.03 and 1.05. Would anyone happen to have a copy of that? Thanks.
#462 Post by Billycar11 » Tue Nov 24, 2020 4:46 am
mossman1120 wrote: Tue Nov 24, 2020 3:50 am I am trying to find a factory copy of the 1.04 version for a WH16NS40. I can only see 1.03 and 1.05. Would anyone happen to have a copy of that? Thanks.
why would you need it?
mossman1120
#463 Post by mossman1120 » Tue Nov 24, 2020 4:54 am
In case one has to RMA a dead drive that came with 1.04
#464 Post by MartyMcNuts » Tue Nov 24, 2020 10:17 am
mossman1120 wrote: Tue Nov 24, 2020 4:54 am In case one has to RMA a dead drive that came with 1.04
If it needs RMAing, just put 1.05 on it.
#465 Post by Billycar11 » Tue Nov 24, 2020 12:49 pm
MartyMcNuts wrote: Tue Nov 24, 2020 10:17 am
This ^
