No Mans Land will not Save
bbishop02
Post by bbishop02 » Sun Jan 02, 2011 5:29 pm
Hi-
I have been using makeMKV successfully with almost all my dvds until this one. Here is the log:
Debug log started at Sun Jan 02 17:20:36 2011 , written by MakeMKV v1.6.3 win(x64-release)
001005:0000 MakeMKV v1.6.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\public/MakeMKV_log.txt
003028:0000 Title #0 was added (18 cell(s), 1:37:32)
003025:0000 Title #1 has length of 26 seconds which is less than minimum title length of 60 seconds and was therefore skipped
003028:0000 Title #2 was added (1 cell(s), 0:02:05)
005014:0000 Saving 1 titles into directory C:/Video/NOMANSLAND
001002:0020 LIBMKV_TRACE: Exception: UpdateTrackInfo failed
005003:0000 Failed to save title 0 to file C:/Video/NOMANSLAND/title00.mkv
005002:0000 Title 1 skipped
005004:0080 0 titles saved, 1 failed
I have tried with and without AnyDvd. I have tried ripping to the hard drive with AnyDVD (which works) and then using makeMKV to use the files from the rip but that didn't work either and gave the same log output. I have also tried using older versions of makeMKV without success.
Any help would be greatly appreciated. Thanks!
Re: No Mans Land will not Save
Post by mike admin » Mon Jan 03, 2011 9:24 am
Please enable and post debug log per http://www.makemkv.com/faq/item/8
bbishop02
Post by bbishop02 » Tue Jan 04, 2011 12:51 am
Thanks for the reply. I did have debugging enabled (can see from where it stated that near the top of the log). What I have posted above is what was recorded in the log file.
Edit: I will also send the .IFO files your way. Thanks!
