Tell your friends!
Scott
5/01/11 7:43:55 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] MakeMKV v1.6.3 darwin(x86-release) started
5/01/11 7:43:57 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
5/01/11 7:43:57 AM [0x0-0x56d56d].Play Blu-ray Disc[64885] Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
5/01/11 7:44:56 AM com.apple.launchd.peruser.501[130] ([0x0-0x56d56d].Play Blu-ray Disc[64885]) Exited with exit code: 1
5/01/11 7:51:01 AM [0x0-0x570570].Play Blu-ray Disc[65233] MakeMKV v1.6.3 darwin(x86-release) started
5/01/11 7:51:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] Optical drive "DVD+R-DL MATSHITA DVD-R UJ-857E ZA0E" opened in OS access mode.
5/01/11 7:51:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
5/01/11 7:51:14 AM [0x0-0x570570].Play Blu-ray Disc[65233] Using direct disc access mode
5/01/11 7:51:28 AM [0x0-0x570570].Play Blu-ray Disc[65233] Evaluation version, 28 day(s) out of 30 remaining
5/01/11 7:51:41 AM [0x0-0x570570].Play Blu-ray Disc[65233] Hit OS X IOSCSIMultimediaCommands bug, used type 0 workaround, see http://www.makemkv.com/osxbd/ for details.
5/01/11 7:51:48 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00215.mpls was added as title #0
5/01/11 7:51:49 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00101.mpls was added as title #1
5/01/11 7:51:49 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title 00214.mpls is equal to title 00215.mpls and was skipped
5/01/11 7:51:50 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00008.mpls was added as title #2
5/01/11 7:51:51 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00102.mpls was added as title #3
5/01/11 7:51:51 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00103.mpls was added as title #4
5/01/11 7:51:52 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00314.mpls was added as title #5
5/01/11 7:51:52 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title 00315.mpls is equal to title 00314.mpls and was skipped
5/01/11 7:51:53 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00100.mpls was added as title #6
5/01/11 7:51:53 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00014.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:51:54 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00051.m2ts was added as title #7
5/01/11 7:51:55 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00050.m2ts was added as title #8
5/01/11 7:51:55 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00049.m2ts was added as title #9
5/01/11 7:51:56 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00048.m2ts was added as title #10
5/01/11 7:51:57 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00047.m2ts was added as title #11
5/01/11 7:51:58 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00046.m2ts was added as title #12
5/01/11 7:51:59 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00045.m2ts was added as title #13
5/01/11 7:52:00 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00044.m2ts was added as title #14
5/01/11 7:52:00 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00043.m2ts was added as title #15
5/01/11 7:52:01 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00042.m2ts was added as title #16
5/01/11 7:52:02 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00041.m2ts was added as title #17
5/01/11 7:52:03 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00040.m2ts was added as title #18
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00039.m2ts was added as title #19
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00038.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00000.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00002.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00052.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00012.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:04 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00053.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] File 00008.m2ts was added as title #20
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00055.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Operation successfully completed
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] Streaming server started, web server address is http://192.168.1.7:51000 or http://localhost:51000
5/01/11 7:52:05 AM [0x0-0x570570].Play Blu-ray Disc[65233] UPnP server enabled on address 192.168.1.7
5/01/11 7:52:07 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x100203e18] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
5/01/11 7:52:08 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x10b919288] main access error: connection failed: Connection refused
5/01/11 7:52:13 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x1008b4f08] dts decoder: DTS channels:6 samplerate:48000 bitrate:1536000
5/01/11 7:52:16 AM [0x0-0x570570].Play Blu-ray Disc[65233] Stream with high frequencies VQ coding
5/01/11 7:52:22 AM [0x0-0x570570].Play Blu-ray Disc[65233] [0x100861b08] avcodec decoder error: more than 5 seconds of late video -> dropping frame (computer too slow ?)
