Not Compatable with Mac BIG SUR
KenVal
#1 Post by KenVal » Mon Nov 23, 2020 7:57 am
Apple say MKV NOT compatible with BIG SUR and cancels installation !!
Re: Not Compatable with Mac BIG SUR
#2 Post by dcoke22 » Mon Nov 23, 2020 3:48 pm
viewtopic.php?f=4&t=23325#p97148
I'm not on Big Sur yet, but I assume one just has to adjust the gatekeeper options, just like on Catalina.
KenVal
#3 Post by KenVal » Mon Nov 23, 2020 8:43 pm
Gatekeeper makes no difference, still says not compatible.
#4 Post by dcoke22 » Mon Nov 23, 2020 10:46 pm
Can you post a screen shot of the error?
replicant69
#5 Post by replicant69 » Thu Nov 26, 2020 2:44 pm
v1.15.3 Installed without error and opens Ok on Big Sur here. Haven't tried ripping anything as no UHD discs knocking about at the mo (which is all I use it for).
Ssaylor
#6 Post by Ssaylor » Thu Nov 26, 2020 3:03 pm
I just installed v1.15.3 and had another issue. I was able to get through the initial scan successfully but attempting to MAKE MKV produces an immediate red caution symbol type error. I didn't think to make a screen shot before reinstalling v1.15.1 but will after I finish my project. v1.15.1 is solid on Big Sur.
nettes
#7 Post by nettes » Fri Nov 27, 2020 4:59 pm
Is there a way to download an earlier version of makemkv seeing that v1.15.1 is reported to work with Big Sur but v1.15.3 (latest version) not?
#8 Post by Woodstock » Fri Nov 27, 2020 6:39 pm
Old versions are kept in the same place as always: https://makemkv.com/download/old/
mudsharkcentral
#9 Post by mudsharkcentral » Sun Nov 29, 2020 3:24 pm
This is strange. I updated from Catalina to Big Sur using v 1.15.3, and it works fine for me. I ripped a disc via MakeMKV this morning and it worked just as it always has.
Hopefully, the next update will get it working for everyone.
spsheridan
#10 Post by spsheridan » Tue Dec 01, 2020 2:21 pm
I used MakeMKV v1.15.3 to rip a BluRay disc on Bug Sur 11.0.1 and it worked as normal.
replicant69
#11 Post by replicant69 » Tue Dec 01, 2020 9:08 pm
I also had no problem ripping a UHD 4K disc with v1.15.3 on Big Sur 11.0.1. If anything it appeared to be pushing faster read speeds (might be my imagination though).
jettlag
#12 Post by jettlag » Wed Dec 02, 2020 11:26 pm
My issue is I cannot rip any DVD. Blu-Rays work fine but DVD's in Big Sur show "No disc inserted".
anyone seen this behavior?
philb1701
#13 Post by philb1701 » Tue Feb 02, 2021 1:46 pm
Hold down the Control key (bottom left key on an Apple keyboard) then click the makeMKV app. Click the Open button and it will allow you to proceed.
#14 Post by dcoke22 » Tue Feb 02, 2021 2:03 pm
jettlag wrote: Wed Dec 02, 2020 11:26 pm My issue is I cannot rip any DVD. Blu-Rays work fine but DVD's in Big Sur show "No disc inserted".
That's probably a fault with your optical drive, not with Big Sur.
kdheslop@gmail.com
#15 Post by kdheslop@gmail.com » Sat Feb 13, 2021 1:14 am
I have a late 2014 13' MacBook Pro Retina 2.6Ghz I-5 with 8GB Ram and 1 TB SSD with Big Sur version 11.2.1 and 11.2 I am having the same problem.
When attempting to run MakeMKV I am getting problematic results. TOday 1 of 3 DVDs would read. No UHD Blu-Rays would read. The program opens, starts to scan disk, at times will pull contents, but when ripping the system crashes and reboots.
If if I roll back to pre-Catalina I am good (getting ready to try Catalina, but never got it installed before and went straight to Big Sur.
