Paddington DVD error
monkeydunker
Post by monkeydunker »
Firstly I find this program so useful.
I just got Paddington DVD (out today in the UK), but I can't get it to work.
I have a debug log, but hat can I do?
Thanks in advance!
Re: Paddington DVD error
Posting the debug log will help us narrow down what isn't working.
monkeydunker
Here it is:
Title #2 was added (2 cell(s), 0:04:00)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #3 was added (1 cell(s), 0:02:18)
Cells 3-end were skipped due to cell commands (structure protection?)
Title #4 has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:02:14)
Title #7 was added (1 cell(s), 0:02:16)
Title #8 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:02:56)
Title #11 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 was added (1 cell(s), 0:16:19)
Title #13 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/1 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15/28 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 was added (14 cell(s), 1:01:44)
Title #17 was added (18 cell(s), 1:32:12)
DEBUG: Code 10551299 at 2v\x6:dUo2"1l{@\:213142128
DEBUG: Code 0 at 2v\x6:dUo2"1l{@\:213143301
DEBUG: Code 0 at <|C!&I&2z{,(s O7|P:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #18 was added (13 cell(s), 1:31:13)
Title #19 was added (13 cell(s), 1:31:13)
Title #21 was added (13 cell(s), 1:31:13)
Title #22 was added (13 cell(s), 1:31:13)
Title #23 was added (13 cell(s), 1:31:13)
Title #24 was added (14 cell(s), 1:01:44)
Title #25 was added (17 cell(s), 1:24:58)
Title #26 was added (16 cell(s), 1:21:18)
Title #28 was added (13 cell(s), 1:31:13)
Title #31 was added (18 cell(s), 1:33:13)
Title 1 in VTS 13 is equal to title 1 and was skipped
Title 1 in VTS 27 is equal to title 1 and was skipped
Audio stream #0 looks empty and was skipped
Audio stream #1 looks empty and was skipped
Audio stream #2 looks empty and was skipped
Subtitle stream #5 is identical to stream #4 and was skipped
Saving 2 titles into directory A:/Video/Paddington
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16588800, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16590848, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16592896, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16594944, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16596992, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16599040, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16601088, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16603136, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16605184, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16607232, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16609280, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16611328, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16613376, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16615424, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16617472, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16619520, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16621568, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16623616, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16625664, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16627712, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16629760, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16631808, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16633856, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16635904, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16637952, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16640000, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16642048, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16644096, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16646144, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16648192, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16650240, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16652288, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16654336, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16656384, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16658432, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16660480, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16662528, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16664576, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16666624, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16668672, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16670720, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16672768, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16674816, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16676864, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16678912, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16680960, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16683008, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16685056, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16687104, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16689152, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16691200, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16693248, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16695296, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16697344, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16699392, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16701440, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16703488, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16705536, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16707584, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16709632, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16711680, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16713728, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16715776, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16717824, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16719872, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16721920, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16723968, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16726016, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16728064, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16730112, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16732160, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16734208, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16736256, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16738304, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16740352, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16742400, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16744448, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16746496, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16748544, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16750592, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16752640, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16754688, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16756736, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16758784, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16760832, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16762880, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16764928, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16766976, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16769024, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16771072, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16773120, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16775168, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16777216, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16779264, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16781312, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16783360, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16785408, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16787456, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16789504, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16791552, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16793600, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16795648, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16797696, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16799744, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16801792, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16803840, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16805888, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16807936, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16809984, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16812032, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16814080, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16816128, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16818176, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16820224, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16822272, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16824320, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16826368, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16828416, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16830464, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16832512, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16834560, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16836608, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16838656, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16840704, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16842752, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16844800, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16846848, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16848896, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16850944, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16852992, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16855040, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16857088, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16859136, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16861184, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16863232, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16865280, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16867328, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16869376, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16871424, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16873472, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16875520, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16877568, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16879616, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16881664, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16883712, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16885760, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16887808, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16889856, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16891904, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16893952, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16896000, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16898048, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16900096, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16902144, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16904192, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16906240, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16908288, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16910336, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16912384, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16914432, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16916480, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16918528, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16920576, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16922624, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16924672, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16926720, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16928768, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16930816, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16932864, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16934912, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16936960, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16939008, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16941056, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16943104, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16945152, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16947200, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16949248, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16951296, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16953344, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16955392, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16957440, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16959488, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16961536, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16963584, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16965632, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16967680, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16969728, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16971776, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16973824, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16975872, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16977920, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16979968, attempting to work around
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/VIDEO_TS/VTS_14_1.VOB' at offset '16982016'
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16982016, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16984064, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16986112, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16988160, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16990208, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16992256, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16994304, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16996352, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 16998400, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17000448, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17002496, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17004544, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17006592, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17008640, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17010688, attempting to work around
The source file '/VIDEO_TS/VTS_14_1.VOB' is corrupt or invalid at offset 17012736, attempting to work around
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/VIDEO_TS/VTS_14_1.VOB' at offset '17014784'
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:121263038
DEBUG: Code 0 at _}>2]/?KC0L=d8 `"oE:121261750
DEBUG: Code 0 at y6*vfE*%I]?KB[pfW2x&:213130559
DEBUG: Code 8308 at y6*vfE*%I]?KB[pfW2x&:29393286
DEBUG: Code 0 at {Sd%j8Wv.P@.V@bGTwF]7:29399013
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 7 to file A:/Video/Paddington/title07.mkv
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16588800, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16590848, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16592896, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16594944, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16596992, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16599040, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16601088, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16603136, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16605184, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16607232, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16609280, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16611328, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16613376, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16615424, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16617472, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16619520, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16621568, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16623616, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16625664, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16627712, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16629760, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16631808, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16633856, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16635904, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16637952, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16640000, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16642048, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16644096, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16646144, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16648192, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16650240, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16652288, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16654336, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16656384, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16658432, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16660480, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16662528, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16664576, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16666624, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16668672, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16670720, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16672768, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16674816, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16676864, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16678912, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16680960, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16683008, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16685056, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16687104, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16689152, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16691200, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16693248, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16695296, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16697344, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16699392, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16701440, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16703488, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16705536, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16707584, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16709632, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16711680, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16713728, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16715776, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16717824, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16719872, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16721920, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16723968, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16726016, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16728064, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16730112, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16732160, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16734208, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16736256, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16738304, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16740352, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16742400, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16744448, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16746496, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16748544, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16750592, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16752640, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16754688, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16756736, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16758784, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16760832, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16762880, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16764928, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16766976, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16769024, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16771072, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16773120, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16775168, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16777216, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16779264, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16781312, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16783360, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16785408, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16787456, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16789504, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16791552, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16793600, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16795648, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16797696, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16799744, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16801792, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16803840, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16805888, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16807936, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16809984, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16812032, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16814080, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16816128, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16818176, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16820224, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16822272, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16824320, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16826368, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16828416, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16830464, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16832512, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16834560, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16836608, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16838656, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16840704, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16842752, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16844800, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16846848, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16848896, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16850944, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16852992, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16855040, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16857088, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16859136, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16861184, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16863232, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16865280, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16867328, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16869376, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16871424, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16873472, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16875520, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16877568, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16879616, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16881664, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16883712, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16885760, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16887808, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16889856, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16891904, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16893952, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16896000, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16898048, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16900096, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16902144, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16904192, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16906240, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16908288, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16910336, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16912384, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16914432, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16916480, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16918528, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16920576, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16922624, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16924672, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16926720, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16928768, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16930816, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16932864, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16934912, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16936960, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16939008, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16941056, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16943104, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16945152, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16947200, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16949248, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16951296, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16953344, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16955392, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16957440, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16959488, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16961536, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16963584, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16965632, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16967680, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16969728, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16971776, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16973824, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16975872, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16977920, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16979968, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16982016, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16984064, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16986112, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16988160, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16990208, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16992256, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16994304, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16996352, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 16998400, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17000448, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17002496, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17004544, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17006592, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17008640, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17010688, attempting to work around
The source file '/VIDEO_TS/VTS_23_1.VOB' is corrupt or invalid at offset 17012736, attempting to work around
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/VIDEO_TS/VTS_23_1.VOB' at offset '17014784'
Failed to save title 10 to file A:/Video/Paddington/title10.mkv
0 titles saved, 2 failed
Thanks again
There are at least two places where the operating system says the disk is unreadable, with messages like:
There are probably more marginal places, given the number of corrupt/invalid messages, where MakeMKV got data back from the operating system, but it wasn't what was expected.
I suggest taking the disk back for replacement, as it seems to be poorly pressed.
stebadham
Post by stebadham »
I'm having the same errors with this disc...
stebadham
Post by stebadham »
Actually, I think it's copy protection - there are several "ghost" titles. On my disc, Title 08, 12 chapters, 5.9GB, appears to be the real one.
