Error Importing One Title from Kavanagh QC Set - Region 2
JohnJ9
Post by JohnJ9 »
I am getting errors when importing a set of Kavanagh, QC discs. The discs are Region 2, and the second episode on Series 4 Disc 2 fails. I actually got the set replaced, and have the same problem on the same title. I've imported the rest of the set with no problem, and have another Region 2 set that I've imported in its entirety without errors. I have an external DVD drive that is set to Region 2 at all times just for this purpose, and it was used for all the other importing. I have a Pioneer DVD player here that plays both Region 1 and 2 discs, and it seemed to play the episode okay.
Debug log started at Tue Sep 25 05:49:49 2012 , written by MakeMKV v1.7.7 win(x64-release)
001005:0000 MakeMKV v1.7.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\jjames/MakeMKV_log.txt
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at 'z$fKhow9}e$[3ww:213137183
003025:0000 Title #0 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 7 cells and 4541 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #1 was added (7 cell(s), 1:15:35)
003024:1000 Complex multiplex encountered - 7 cells and 4530 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (7 cell(s), 1:15:25)
003024:1000 Complex multiplex encountered - 7 cells and 4551 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #3 was added (7 cell(s), 1:15:45)
001003:0020 DEBUG: Code 233 at 7sjQrxNlZrqIve+Ft0KI+v2t:0
005014:0000 Saving 1 titles into directory C:/Users/Public/Documents/MakeMKV/Kavanagh/Series 4 Disc 2
001003:0020 DEBUG: Code 86400000 at zyx^)BgD_F])\bL 6Vr:29393700
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914915328, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914917376, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914919424, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914921472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914923520, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914925568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914927616, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914929664, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914931712, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914933760, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914935808, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914937856, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914939904, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914941952, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914944000, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 914946048, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915406848, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915408896, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915410944, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915412992, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915415040, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915417088, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915419136, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915421184, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915423232, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915425280, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915427328, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915429376, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915431424, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915433472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915435520, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915437568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915771392, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915773440, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915775488, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915777536, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915779584, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915781632, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915783680, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915785728, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915787776, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915789824, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915791872, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915793920, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915795968, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 915798016, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916506624, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916508672, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916510720, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916512768, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916514816, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916516864, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 916518912, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917485568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917487616, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917489664, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917491712, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917493760, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917495808, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917497856, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917499904, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 917501952, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918220800, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918222848, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918224896, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918226944, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918228992, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918231040, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918233088, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918235136, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918237184, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918239232, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918241280, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918243328, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918245376, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918247424, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918249472, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918251520, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918253568, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 918255616, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 920180736, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 920182784, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 920184832, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 920186880, attempting to work around
004004:0000 The source file '/VIDEO_TS/VTS_03_1.VOB' is corrupt or invalid at offset 920188928, attempting to work around
001003:0020 DEBUG: Code 16 at zyx^)BgD_F])\bL 6Vr:121266856
I have the entire log file if wanted.
MakeMKV_log.txt
(804.71 KiB) Downloaded 572 times
Re: Error Importing One Title from Kavanagh QC Set - Region
Post by mike admin »
I have to ask for a lengthy task - please make and send a test dump per instructions at http://www.makemkv.com/onlinehelp/testdump.html for a first title that fails.
JohnJ9
Post by JohnJ9 »
Test done, and URL sent to support.
JohnJ9
Post by JohnJ9 »
Did this ever lead to anything?
